Why external hard drive?
I recently got a new lap top and also made a purchase of the Mbox 2 Mini. I was told I should buy an external hard drive as well. How do I use the external hard drive and what is it for? Or is it only to back up files? Sorry I'm confused and just don't know if I should shell out the extra cash or not.
Thanks. |
Re: Why external hard drive?
First off, this should be moved to the LE thread, as this is the HD thread.
That said, welcome to the DUC. An external hard drive is necessary because when recording audio, your system drive needs all of it's resources to read what is happening, as well as run the program. Trying to record to the system drive on top of that is asking way too much. An external hard drive is needed (especially with laptops) to take the burden off of the system drive, as well as to store your audio. You need a firewire drive. USB drives aren't technically supported due to access speed. When you start up PT, you can go to the "Setup" menu, click "disk allocation," and choose your external HD. This will record your session to that drive. I set up mine with different folder for each session and such, to keep everything organized.
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
If anyone want to move this thread, by all means go ahead!
I was thinking about going with a eSata connection because I heard that would be fast. Could anyone suggest me a good hard drive for around $100? |
...moved to LE forum
I run eSata on my session drive that has FW connections. I don't notice any difference. with a laptop i think fw has a more physically stable connector (like in case you bump it and bend it. eSata is probably easier to break but I think it's technically faster than FW. Either way is fine.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002) |
Yes, eSATA should work just fine. I would hit newegg and similar and look for a drive case with an eSATA port(maybe even one of those desktop gizmos that you just stick the drive in the top). Your best bet will be a case with lots of metal(to act as heatsink) or something with a fan. I bought a large case for my DVD burner but you can get brackets to mount a 3.5" drive in a 5.25" case.
Am doing some test recording 16 tracks in MBOX PRO in the same Hard drive where system C is and is working at moment,buffer at 512
On XP system, I did also on Windows 7, 32bits works too,always in one internal hard drive, more than 30 minutes allready Seagate momentum 250 gb x 7200 rpm PT 8.0.1 laptop HP NW 9440 Next I'll do whith Windows 7 64 bits
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
You'll do just fine with an external stand-alone F/W drive. (I don't think Albee realized you were on a laptop.) Give it a cool name like Audio Drive, or something. Install PT on you're system drive "C" but when you create a session, save it to your new drive. I know it kind of defeats the purpose of having a laptop but is recommended. In emergency's, like flying or something, I have had success with partitioning the internal drive and saving to the new partition. (Not recommended) Oh god, I didn't say that again did I?
"Am doing some test recording 16 tracks in MBOX PRO in the same Hard drive where system C is and is working at moment"
Don't worry, it'll QUIT behaving when you least expect it. |
not happend in more than one hour, i repeat more than six times only failed when I had 12gb free in Hard drive in smaller HD 100gb x 7200 whith 50% gb (50gb)free of the HD works perfect
External Hard Drive Fan? | Sonic Blue Meanie | Storage Subsystems | 3 | 10-12-2011 11:41 AM |
External dedicated external hard drive | JuanCarlos | General Discussion | 1 | 02-15-2010 03:11 PM |
External hard drive mix-up/ | bzb888 | Pro Tools TDM Systems (Mac) | 2 | 09-13-2007 08:29 AM |
External Hard Drive vs. System Drive | evman108 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-30-2006 01:49 PM |
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be | Fucius | General Discussion | 4 | 03-19-2002 11:26 PM |
