Re: 003 will not sync with S/PDIF
You can also leave the digi as master, in which case you need to remove any clock speed setting in the TC, try changing the 48mhz to spdif, if possible, and leaving the digi on internel.
You will be telling the TC to recive the clock data from spdif. |
Try this page p41 of the manual in english
http://www.tcelectronic.com/Default.asp?Id=11356 I get the impression that on your drawing it should say, on the bottom of the box on the right, SPDIF THRU. Check on the level settings page do you have a clock speed showing from the spdif entry? if so you are set to external clock, ie the digi, this is why the spdif sync is greyed out in protools. Iain |
I can't sync via s/pdif - Digi 003 | Tritono9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-26-2010 08:33 AM |
Mbox2 S/PDIF inputs don't sync ? | LynxAudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-01-2007 07:26 PM |
How to Sync Roland VS to Import w/ S/PDIF Optical | clampire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 07-12-2005 04:38 PM |
Internal/S/PDIF sync & Digi001 | lochgarman1798 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-09-2002 10:57 AM |
Video clock sync into s/pdif Digi001 ? | johngray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-10-2001 03:08 AM |
