Bug, or feature? Freezing input monitor tracks
I've used busses as far back as I can remember, and when my cpu starts creaking I've just frozen the busses I'm not working on to free up some cpu cycles.
But I recently updated to the new version, Pro Tools 23.3, and now it seems I'm unable to freeze tracks that are on 'input monitor' Any ideas? Is this something Avid instigated deliberately, or is this a bug? Last edited by audiopimp; 06-06-2023 at 11:37 PM. Reason: clearing up my stupidity |
Re: Bug, or feature? Freezing isolated tracks
You mean you freeze aux tracks? If an aux has no signal feeding it what does freezing it mean? I've never tried freezing one without that before and I'd have never expected it to work. If you have extra tracks not doing stuff, and presume plugins on the track that are consuming CPU just make those tracks inactive, or try dynamic plugin processing and see if that helps.
Are you sure you don’t mean commit track not freeze track?
You can definitely commit an Aux track but as Darryl pointed out, I don’t think you can freeze an Aux track as there is no audio on the timeline. I could be mistaken on the latter as I don’t really use freeze. I do use commit though and use it to render Aux busses all the time. Sent from my iPhone using Tapatalk |
You can freeze aux tracks.
I think we need to know what the OP means by "isolated tracks". |
I cannot fathom what freezing an aux track with no content means or why not being able to do that would be an issue. And yes I also have no clue what "isolated track" means here either. |
Apologies for my stupid nomenclature. Isolated; My bad, let's correctly call it INPUT MONITOR.
Using audio tracks as busses (as opposed to using aux tracks), I put them in 'Input monitor', route a bunch of stuff to them (with some heavy CPU plugs) and previously to this latest version, you could FREEZE so it renders a temporary audio file, thus freeing up the CPU. There's no audio file on the input track, just a bunch of feeds from channel & fx routing |
Freezing tracks? | nightowls | Pro Tools | 4 | 09-20-2022 11:00 PM |
Any downside to freezing tracks? | dg27 | Pro Tools 12 | 10 | 09-15-2018 02:15 PM |
Freeze without Freezing Inserts - Feature request? | Dizzi45Z | Pro Tools 2018 | 4 | 08-04-2018 04:32 AM |
Freezing rewire tracks? | Ru_C | Pro Tools 12 | 6 | 12-12-2017 11:33 AM |
Printing/Freezing tracks in PT9? | JonesH | Pro Tools 9 | 0 | 09-14-2011 01:56 AM |
