PtslCCppExport.h is missing (no file or directory)
I tried writing, compiling, and running the example program (in the root directory's README.md), but I am getting the error:
Code:
Source/CppPTSLClient.h(71): fatal error C1083: Cannot open include file: 'PtslCCppExport.h': No such file or directory Therefore, why am I getting this error, knowing I followed the example? I imagine when building the client, these issues regarding the OS should be taken care of, so the resulting code would be portable across operating systems. For reference, the example program is: Code:
#include "CppPTSLClient.h" PTSLC_CPP::ClientConfig config { "localhost:31416", // server address -- note the server port! false, // turn off stand-alone mode -- look for a server instead of launching our own (see CppPTSLClient::LocateServer) false // do not skip auto launch -- try to launch Pro Tools if it is not running already }; auto client = std::make_unique<PTSLC_CPP::CppPTSLClient>(config); PTSLC_CPP::RegisterConnectionRequest registrationReq; registrationReq.companyName = "YOUR COMPANY NAME"; registrationReq.applicationName = "YOUR APPLICATION NAME"; auto registrationRsp = client->RegisterConnection(registrationReq); parse_response(registrationRsp); //void Import(const ImportRequest& request); PTSLC_CPP::ImportRequest request; request.commandType = PTSLC_CPP::CommandType::Import; request.sessionPath = "D:\\ProTools\\Library\\new_session\\new_session.ptx"; request.importType = PTSLC_CPP::ImportType::Session; request.audioOptions = PTSLC_CPP::AudioMediaOptions::CopyFromSource; request.audioHandleSize = 1000; // in ms request.videoOptions = PTSLC_CPP::VideoMediaOptions::CopyFromSource; request.matchOptions = PTSLC_CPP::MatchTrackOptions::ImportAsNewTrack; request.playlistOptions = PTSLC_CPP::MainPlaylistOptions::ImportOverlayNewOnExistingPlaylists; request.trackDataPresetPath = "D:\\ProTools\\Library\\Test\\Test.ptpreset"; request.clipGain = true; request.clipsAndMedia = true; request.volumeAutomation = true; void parse_response(PTSLC_CPP::CommandResponse * rsp) { if(rsp) { if(rsp->status.type == PTSLC_CPP::CommandStatusType::Completed) { std::cout << "Command completed successfully!\n" } else { std::shared_ptr<PTSLC_CPP::CommandError> error = rsp->error; string errStr = error ? error->errorMessage : string(); switch(rsp->status.type) { case CommandStatusType::CompletedWithBadResponse: { std::cerr << "Command completed but returned an invalid response." << std::endl; break; } case CommandStatusType::Failed: { if(errStr.empty()) { std::cerr << "Command failed with no error message." << std::endl; } else { std::cerr << "Command failed with error message: " << errStr << std::endl; } break; } case CommandStatusType::FailedWithBadErrorResponse: { std::cerr << "Command failed with a bad error response." << std::endl; break; } default: break; } } } else { std::cerr << "Response pointer was null" << std::endl; } } int main(int argc, char *argv[]){ auto response = client->Import(request); parse_response(response); return 0; } |
Re: PtslCCppExport.h is missing (no file or directory)
I found the answer. I was using the files in the Source directory. When I switched to using the include directory located in "install\Debug\PTSLC_CPP\include" the error was resolved.
No such file or directory (2) | IrelandM | Pro Tools 12 | 3 | 03-05-2021 01:05 PM |
Plugin directory security weakness - check your plugin directory permissions | Darryl Ramm | macOS | 13 | 01-21-2020 04:54 AM |
No such file or directory (2) while creating "Plug-In Settings". | SnakeyD2 | Pro Tools 11 | 3 | 11-08-2016 11:12 AM |
master PT audio file directory? | tragibigzanda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-28-2009 01:11 PM |
Normalized audio file in root directory | avaldes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-14-2006 08:14 AM |
