Problem with GetFileLocation
I have the following problem with the GetFileLocation command and I don't know if this behavior is intended or if it's a bug. I have a final mix track with recorded audio on it. I consolidate this material with ConsolidateClip. Then I want to get the location of the newly created file with GetFileLocation. To do this, I select the consolidated file and use the filter FileLocationTypeFilter::SelectedClipsTimeline. Unfortunately, I now not only get the location of the consolidated file, but also all the clips that were previously recorded on the track, even if they are no longer visible on the timeline. Is it possible to get only the location of the consolidated clip? Thanks very much! Nick |
Re: Problem with GetFileLocation
Hi Nick,
Thank you for reporting this. This is not intentional; we have logged this issue as PT-303845. Rob
Rob Majors Avid Software Engineering |
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? | Priz | Windows | 1 | 09-25-2011 12:51 PM |
ELS Vocoder plugin problem and fresh Windows 7 install problem | Thorpey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-09-2011 05:03 AM |
Need opinions: Do I have Core card problem or computer problem? | johnnyv | Pro Tools TDM Systems (Mac) | 2 | 08-11-2010 06:36 PM |
digi 002/7.4 installation problem/not recordable volume problem | fifthflaw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-08-2008 01:28 PM |
Audio Regions Display Problem & Grabber Problem | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-25-2002 04:08 AM |
