Old 11-17-2003, 12:16 PM
Eric Lambert's Avatar
Default Total possible inputs with 192 or 96 I/O?
Assuming I add on a legacy interface (I'll be using AES on an 888/16), how many total inputs can I use at one time?
Some have said that if I'm using a legacy product, I lose 8 of the inputs. This doesn't seem right to me.
Shouldn't I still get the 16 analog inputs PLUS the 8 AES inputs from the legacy interface?
Old 11-17-2003, 12:32 PM
nikki-k nikki-k is offline
Default Re: Total possible inputs with 192 or 96 I/O?
Hi!
Each PRIMARY interface connected = 16 I/O simultaneously, period. (ie, one 192=16, one 192 with extra analog in card, legacy ADAT, etc still = 16 simultaneous)
WHICH 16 get used, almost any combo, configurable thru Setups->Hardware, changeable while session is open. Very cool Combine that with a DigiPre, and one's lazy ***** doesn't need to even move much, except to place mic's.
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
Old 11-17-2003, 12:42 PM
One Track Music One Track Music is offline
No, it's 16 for the primary interface (192) PLUS another 16 from the legacy port. At least that's what I'm using: 192 + 1622.
Cheers,
Joel
www.joeldouek.com
"Show me your Pasodoble!"
Old 11-17-2003, 07:11 PM
I appreciate both responses, but unfortunately they diasagree. This is EXACTLY what I've been getting - one person says "16 imputs max" and the next person says "16 + legacy inputs"
Since I don't know either one of you two, I'm figuring that both responses cancel each other out and I still don't know the truth.
I'd rather not spend an additional $2000 if I don't have to, so please respond only if you are sure.
Old 11-17-2003, 07:16 PM
Touchwood Studios Touchwood Studios is offline
An 888/16 will NOT work on the Legacy Port. Also The legacy port will NOT work above 48 K so Both are true depending on the Sample Rate of the session.
Old 11-17-2003, 07:43 PM
Touchwood is correct (I didn't notice the 888/16 ): The Legacy Peripheral port allows for connection of 888|24, 882|20, 1622, or 24-Bit ADAT Bridge I/Os*, whereby you would have an additional 16 ins. So in your case I guess not. Sorry for the confusion. Of course you could pick up one of the above 20 or 24 bit legacy interfaces for considerably less than 2000$ and be good to go.
Cheers,
Joel
www.joeldouek.com
Old 11-17-2003, 10:04 PM
I didn't know that an 888/16 isn't compatible with the legacy port. I have an 888/24 that I can use for this, and I'm not going above 48K, so I guess I'm alright.
On a 2nd system I'll be connecting an ADAT bridge on the legacy port, but isn't it limited to 8 channels of lightpipe because the legacy port has only one connector? If I'm not mistaken, an ADAT bridge uses two connectors to achieve all 17 channels.
Regardless, is it now safe to say that I CAN get at least 24 channels of input with a 96 I/O with an 888/24 attached to the legacy port? This has been confirmed, hasn't it???
Old 11-17-2003, 10:48 PM
Hi!
Sorry- was a bit tired...
The first interface connected to the HD Core card will act as the PRIMARY. It has the ability to have an additional 16 channels of I/O "piggyback" the 16 I/O available to the PRIMARY.
WIthin the limitations of which legacy products will work with the 192, adding say, an ADAT24 would give you 16 channels of I/O IN ADDITION to the 16 channels of I/O from the 192.
Since the 192 has two "expansion ports," you could attach another 192 and/or an appropriate legacy device (or two legacy devices that are each limited to 8 I/O by design, ie 888/24, using a special cable from Digi that sorta merges the two into a pseudo-16 I/O device); however, only ONE of the two ports is available at any given time (at least that is how it reads ).
AFAIK, each HD card is limited to 32 channels of I/O (Group A and Group B).
Sorry about the screwy first post!
nikki k
Old 11-18-2003, 12:21 AM
Well, finally it seems clear as day. Thanks. Good news for me.
Old 11-18-2003, 04:59 PM
Wyn Wyn is offline
I think the answer you are looking or is:
With a 192 you can do (analog): 32 in x 24 Out OR 24 in x 32 Out.
Assuming you have the analog expansion slot occupied and use the legacy port to connect two qualified 888s. BOTH 888s can be used simultaneously via the legacy port.
Using the 888s, the maximum sampling frequency will be 48-kHz.
You must use the legacy port of an HD interface that is connected DIRECTLY to a core or process card.
Wyn Davis - Total Access Recording Studios
Redondo Beach, California
Using S/Pdif on Mbox 2 Pro for total 6 inputs..? martinstaunton007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-22-2010 02:10 AM
HD 192 how many inputs in total 2fly Pro Tools TDM Systems (Mac) 2 06-09-2008 02:26 PM
PT 7.4 Total Failure Andrew. D Pro Tools TDM Systems (Mac) 11 12-04-2007 03:21 PM
HELP! Total Newbie... :) GoofyDawg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-11-2007 04:57 PM
Sorry am total new in all this and need a little help please socata 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-17-2002 05:47 PM
