Midi timing
made an arrangement in PT 7.4 and the same with Logic 8.02 - very interesting! the timing with playing Midi and VIs in Logic is much better than in PT. You get a springy, elastic feeling in L8 Then I used plogue bidule in PT, it´s a virtual VST rack with rewire, that you can use with PT and wow: on a rewire bus battery 3 rocks a lot more than being a RTAS plug digidesign will say, "that´s the problem with Native Instruments, but I think, this isn´t true, because AIR instruments like xpand or strike have the same tiring groove Hope, this problem will change in PT 8 On the other side I am a big fan of PT Mr.O |
Re: Midi timing
For me, the HIGHER the BUFFER, the WORSE the TIMING !!!!!
Been this way since Protools 6.0 here. I wish theyd just allocate a certain amount of memory that dealt with JUST the midi so it wouldnt go all over the place. Logic still has the best midi timing yet.
MacPro 8 Core,2.4, 14 Gig Ram. OSX 10.8.2 |
Re: Midi timing
Same here.
Midi timing in Logic is excellent and mix sounds tight. PTLE 7.4.2 timing is all over the place. Frustrating indeed. PT 8 i am guessing will have the same midi timing issue. |
Re: Midi timing
For Recording, lower the Hardware Buffer Size, for Playback set the H/W Size back and use MIDI Track Offsets.
filosofem |
Re: Midi timing
Setting up a MIDITRACK OFFSET in 2008!!!!!!
Midi has been going since 1983 and DIGI cant keep the timing on tight?? No thanks, Ill use Logic or Cubase for MIDI
Midi timing in PT =>6.0 | Zeus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-26-2003 03:36 AM |
MIDI Timing on PT LE | DooDooDoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 25 | 09-02-2002 10:54 AM |
001 midi timing/midi clock/MTC...any probs? | Adam Inglis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-01-2001 09:33 AM |
MIDI to CV midi timing ??(kenton) any good ? | sandman | MIDI | 1 | 04-21-2001 06:36 AM |
Midi timing on 001 | who | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-11-2000 08:50 PM |
