Old 12-18-2010, 08:51 PM
JCollee JCollee is offline
Exclamation Screen Problem with brand new profile
We have just taken delivery of two full profile rigs and the screen output of one is not well. It's yellowy where it should be white! I have changed VGA cables several times and it worked initally, but has no effect now. I then used our other desk with the same FOH, Stage, link cable and monitor and it was fine. The head of video here and myself are farily certain it may be a loose connection somewhere inside the desk, I just wondered if anyone has had the same problem and could offer a solution please.
Cheers guys
JC
Old 12-19-2010, 09:30 AM
Avid Pro Mixing Support's Avatar
Avid Pro Mixing Support Avid Pro Mixing Support is offline
Default Re: Screen Problem with brand new profile
JC,
There is probably a color channel getting lost in between the FOH Rack and the monitor. Can you try swapping just the FOH Link cable between the 2 systems to see if the problem follows the cable? It is possible that a pin has been damaged, or perhaps there is a manufacturing issue.
If it's not the cable, then it must be an internal component of the FOH Rack or Profile. Let us know the results of your troubleshooting.
Thanks,
Rich
Old 12-19-2010, 11:27 PM
Hi Rich, thanks for the speedy reply. I have already tried to repeat the problem with a different link cable. I have also swapped my other desk into the same set up as before and it fixed the problem. This leads me to believe it is an internal issue within the console. I have just had two guys from our local resellers out here to look at it and they seem to agree. fingers crossed a new internal cable and maybe a new card will sort it out.
Cheers matey
JC
Old 12-20-2010, 05:39 PM
Kenmillerjr's Avatar
Kenmillerjr Kenmillerjr is offline
...because of this posting, I threw some extra VGA cables in my audio workbox today. Never know when those dinky pins might get bent...
Ken Miller, Jr.
Audio Engineer
Southside Baptist Church | Warner Robins, GA
| VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Old 12-24-2010, 12:28 PM
Tiginbna Tiginbna is offline
I have had pushed pins on the panel mounted connector at the local rack before. I believe the lower case "m,n, and o" are the colors for the VGA at the connector. Check the pins.
Brand new Profile KrisHeinold VENUE Live Sound Systems 5 12-23-2013 07:19 AM
Trackball cursor not showing on profile screen borez VENUE Live Sound Systems 0 07-20-2011 04:37 AM
Venue Profile Boot Screen Customization? voidmix VENUE Live Sound Systems 2 03-03-2011 12:35 PM
Profile fader layout is different to what is show on the screen Edd S VENUE Live Sound Systems 5 07-03-2010 10:29 PM
Screen crapped out on my Brand New Powerbook G4!!! CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-21-2003 04:32 PM
