Driving PA on Matrix Faders
Hello All,
I am setting up a system with L,LL,R,RR,FF.. I think the best way to do this would be to let the Matrix faders 1-5 provide the signal to my XTA drive.. I am confused as to how to actually finalize the routing to the Stereo Buss. Is it really just as straight forward as going to the Outputs tab, click on say Mtrx Fader 1 (turns blue).. then selecting the Matrix Mix L.. using the pull down and selecting Left?.. I am in stand alone so I can't pass audio.. Do I also have to select all inputs and then select the Matrix faders or is it implied since it already routes through the Stereo Buss?? Any help is greatly appreciated. Icky |
Re: Driving PA on Matrix Faders
Nope it is pretty much that easy. Select the matrix (1 or 2 etc.) then do the drop down menu to make sure what ever you want assigned to the matrix is there, turn the knob up and make sure it is on. It is variable in case you want to do processing to the master buss before the matrix. Once you have your inputs selected to the master L/R buss they will be in the matrix as well.
Tig |
Custom Faders moves position of all other faders!?! | freeBase | ICON & C|24 | 5 | 02-26-2009 06:44 PM |
Stereo Matrix??? | FOHMIXER22 | VENUE Live Sound Systems | 1 | 11-01-2007 05:31 PM |
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... | domsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-08-2004 07:06 PM |
M-S matrix | tirt1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-01-2002 08:30 AM |
where is the matrix ? | sandman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-12-2001 12:39 AM |
