#21
Re: MTRX Studio HDX and Dolby Atmos Production Suite
That is a bit odd. Does increasing the DVS latency improve things? How about removing the switch and going point-to-point (really this should not affect things, but it's worth trying). I suppose you could also look at the PCIe pool allocation but 64 channels is only 75Mbps.
https://lukehoward.com/ |
#22
I need the switch because I have a Lynx Hilo that is Dante as well so even if I go point to point then I’ll loose my headphones. Changing DVS latency doesn’t make a difference.
#23
The dropping in and out part sounds like something akin to an IP conflict to me. Is Dante Controller flagging any event or clocking errors (you can access them by double clicking the green/red squares in the bottom right of the app)?
What happens if you strip the network setup right back - just plug a single ethernet cable between your Mac and MTRX, selecting the appropriate ethernet port in both Dante Controller and DVS?
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
#24
It does seem like it’s seeing errors of some sort. I can check out the log. Again, I can go point to point to try and see if that helps figure out an issue but unfortunately I can’t leave it that way because my headphone amp is Dante as well. I’ll try it and let you know. Again, thanks for all the help.
#25
It's more for the purposes of fault finding than anything else. If the MTRX and DVS work fine together, then we know the issue probably exists somewhere else in the network.
#26
Good points. Wireshark and PTP Track Hound can also be useful for diagnosis, but you have to know what you're looking for :)
I am starting to see why Dolby is extremely specific at what systems they qualify
#27
Right. I'll try right now. Thanks
#28
ok so I connected the MTRX directly to the Mac Pro and still no luck. Same issues. Here are some lines from the event logs...
Dante Controller Event Log version 1.0.0 2021-06-27 18:19:23 PDT 1624843163437 Warning "" "Device 0060DB030237 (device name not known) is now a primary leader" 2021/06/27 06:19:18.966 Fatal: Dante Controller Version 4.4.0.8 2021/06/27 06:19:22.965 Fatal: Agent Websocket Port is 49220 2021/06/27 06:19:22.966 Fatal: Agent Webserver Port is 49221 2021/06/27 06:17:59.655 Fatal: Dante Controller Version 4.4.0.8 2021/06/27 06:18:01.042 Fatal: Agent Websocket Port is 49443 2021/06/27 06:18:01.042 Fatal: Agent Webserver Port is 49444 |
#29
Interesting. Do you have wifi enabled on your Mac?
#30
No. But obviously I do have a 2019 Mac Pro where you need the adaptor to even get it to work with Dante but honestly I don't know why it would work fine (it's been set up that way since September) and now with the HDX and Hybrid it's not working. Again, the only things I changed were the routing in the Dante Controller (not sure why any of that would make a difference) and the new PT software. HDX is showing up fine with 64 channels in the Audio Midi setup. HDX1 is in the proper slot. Seems like it all points to Dante but I don't know what else to try.
FS: Dolby Atmos Production Suite License | LDS | Buy & Sell | 1 | 10-20-2020 02:37 PM |
MTRX Studio + Atmos Prod Suite | ViciousLullabyz | Post - Surround - Video | 8 | 07-08-2020 03:45 PM |
Dolby Atmos Production Suite 3.02 download | LDS | Post - Surround - Video | 3 | 08-20-2019 07:03 AM |
Dolby Atmos Production Suite | garnoil | Post - Surround - Video | 2 | 03-13-2019 08:34 AM |
Dolby Atmos Production Suite | subhuffer | Post - Surround - Video | 20 | 03-10-2019 06:40 AM |
