ilok One question
Anyone notice a problem with ilok 1's not being recognized with a powered USB 3 hub? I can connect my ilok 1's to the USB port of my new MBP (with USB 3) but they won't light up or be recognized with the hub. Ilok 2's are just fine in either.
Nathan
Studio: Mac Mini 2.6 GHz i7 16GB RAM PT 2019 and 10.14 UA Apollo Quad Outboard: 2 x Summit Audio 2BA-221>TLA 50>EQF-100 2 x dbx 165a 4 x Shadow Hills GAMAhttp://humpbackmedia.net[/SIZE] |
Re: ilok One question
I understand that. I have been using a USB 2 hub for quite a while with no issues. But with the new machine and USB 3 connectivity, and I don't want to downgrade the bus speed - thus buying a USB 3 hub. I can plug the ilok 1 into the USB 3 port on the machine directly, but don't want to burn the port or make the ilok really inaccessible (the Mini will be racked) if possible.
It sounds like your newer USB3 hub is backwards compatible with USB2 but not USB1. The USB3 specification should be compatible but depending on the manufacturer it may have overlooked USB 1 (USB 1.1) compatibility. The old key-shaped iLok is USB 1.1. Maybe a different USB3 hub will work.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Yeh - this makes sense, Obsidian. Bummer though.
And Craig, I'll give that a try. Thanks to both of you for the suggestions.
iLOK broken, transfer license to good iLok question | Jay Terrien | Windows | 12 | 09-18-2012 05:12 PM |
PT7.2-iLok and PT7-iLok question | RobMacki | Pro Tools TDM Systems (Mac) | 1 | 08-08-2006 09:33 PM |
iLok Question | rolotamazi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-17-2006 07:00 PM |
to iLok or not to iLok this is the question | JohnnyW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-23-2006 06:25 PM |
iLok question | matts9383 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-23-2004 10:45 PM |
