Old 12-29-2002, 04:56 PM
Terry Dycus Terry Dycus is offline
Default 002 & Powerbook G3 "Wallstreet"
Anyone have a working 002 system with a Powerbook G3 "Wallstreet" 292MHz using a pc card for firewire interface? I've tried to make mine work, but I get freezes. 002 works fine on my iBook. I've tried all the tricks I could think of such as trashing prefs, reinstalling, uninstalling, external drives, internal drives.
Thanks.
Best regards,
Terry Dycus
Old 12-29-2002, 06:22 PM
Frank S Frank S is offline
Default Re: 002 & Powerbook G3 "Wallstreet"
I would guess that either
1. Using a firewire PCMIA card to the 002 is the problem. Its not a supported configuration, and I wouldn't be suprised that it doesn't work.
2. Your wallstreet G3 is just too slow to run the 002.
Frank S
[email protected]
Old 12-29-2002, 08:04 PM
Frank, you are of no help to me unless you have experience with the configuration I'm asking about. Too slow? Funny, my Wallstreet runs PT24 w/32 tracks with a Magma Chassis and Apogee AD8000's. And that's not a "supported" configuration either.
Thanks.
Best regards,
Terry Dycus
Old 12-29-2002, 08:17 PM
As for the PCMIA card, I quote from the compatibilty for 002:
"Digi 002 Qualified FireWire PCI & CardBus Cards
A 1394 ("FireWire") controller/interface is required to connect the Digi 002 to your computer. Some computers have built-in 1394 controllers, while other computers require add-in 1394 PCI or PCMCIA controller cards (purchased separately)
CardBus FireWire Adapters for Laptops:
SIIG 1394 CardBus
ADS Pyro
Swann SwannFire FireWire CardBus
Adaptec FireConnect"
Best regards,
Terry Dycus
Old 12-30-2002, 08:30 AM
Terry - sorry to NOT be of help to you - I really didn't mean to be condescending, rude, or anything else for that matter.
I just highly doubted you'd be able to get a Wall street G3 with a PCMIA card running - the FW through PCMIA may be too slow (I saw similar problems when running my Lombard G3-> Newertech FW PCMIA card -> Firewire CD burner - it can't pass data through to burn faster than 4x), and the Wallstreet I believe is just too slow to run PTLE with the increased CPU overhead that a firewire audio interface demands. I wouldn't have been surprised that it will work using a Magma under TDM, since thats ultimately gonna require less CPU overhead.
That being said, if you are going to quote the Digi compato docs, I'd ask you to notice that your machine is NOT supported. The G3's start at the PISMOs, and as such - all the compatable machines are Firewire 'native'and significantly faster than the Wall street. I actually found it kind of curious that digi even tested PCMIA cards since all the supported Macs don't need 'em or can't run 'em (ibooks).
Finally, are you running one of the compatable FW card listed above- maybe thats the problem?
If I get a chance, I'll install 5.3.2 on my Lombard, and try it through the Newer PCMIA card. I really wasn't trying to bust your chops.
Frank S
[email protected]
Old 12-31-2002, 12:22 AM
I've only tried the Adaptec PC Card.
Best regards,
Terry Dycus
Old 02-11-2003, 12:31 AM
trakbytes trakbytes is offline
Frank S,
Just picking up this thread, as I am now looking at an 002 as a second system to my Mix3...
Did you ever try the 002 with the Lombard and Newertech firewire card? That is the same system I have. The card seems to work pretty well with my EZ Quest Cobra 120 Gig drive, but I haven't used it for anything else. Would be nice to hear if you got it to work. Thanks.
rcm
Save early and often! (or once a day whether you need to or not...)
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
"Unable to locate digidesign" 002 with PowerBook G4 Hear Me Shimmer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-16-2009 05:17 PM
Powerbook 12" and 17" unable to create DAE deck Seller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-19-2003 08:50 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
