Re: Spectrasonic problem in Pro Tools 8
I too reinstall 10.5.5 and PT8 don't see Stylus RMX!!! In Logic 7.2.3 all work!
Has rmx plugin in the plugs folder got the extension .dpm after it. it needs to be added manually to be seen in PT8. have done this and it is working fine so far. Chris
FYI: I've only tried this in a G5 PPC. I used Fxpansion VST to RTAS Adapter 2.1-
I download the VST versions of Atmoshpere & Trilogy. I ran the adapter to create the RTAS shells. So far my client says it's working.
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
Trilogy and Atmosphere are not compatible with Pro Tools 8 on Intel Macs. If you're on a PPC Mac, the latest versions should work if you put .dpm after the plug-in name, though this is NOT recommended or supported. |
I have had that problem before when upgrading..... and only with spectrasonics plugs. The only thing that ended up working is to use a utility that will not only repair permissions, but also clear the cache.... system optimizer X used to do the trick... it is now called SOCKS. iI never was able to get an answer from Spectrasonics about it.... go the info from a great tech ...
try it! |
Atmosphere crashing PT 7.0..........spectrasonic | natural | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-10-2006 06:16 AM |
Spectrasonic Atmosphere,Stylus,and NI Kontakt too | moonmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-15-2004 04:39 AM |
Spectrasonic plugs crashing Accel on a G5 | kirkgale | Pro Tools TDM Systems (Mac) | 8 | 01-29-2004 07:08 AM |
How many Spectrasonic plugins can I expect? | chilisexnbeer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-17-2003 04:02 AM |
STYLUS SPECTRASONIC | Gabriel Caraballo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-31-2002 12:31 AM |
