Old 03-16-2021, 05:33 PM
dominicperry dominicperry is online now
Default HEAT on Carbon
Does HEAT run on Carbon? I mean, if you use HEAT and put a bunch of tracks into DSP mode, do you get HEAT running on those tracks on DSP? (I'm not clear where HEAT normally lives as it's not a traditional plug-in).
Old 03-16-2021, 11:06 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: HEAT on Carbon
Hi Dominic,
HEAT is Native-only on Carbon. When you put a track in DSP Mode HEAT is automatically bypassed. We made this decision because HEAT is primarily used for mixing and DSP Mode is primarily used for tracking. And, we felt that the DSP load taken up by HEAT could be better used for other DSP duties like plugin processing and mixing.
If you're a Carbon user, would you like DSP Mode support for HEAT? And, for which workflows?
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 03-17-2021, 05:33 AM
Originally Posted by Kyle Splittgerber View Post
Hi Dominic,
Thanks Kyle.
I'm not a Carbon user but I am interested.
I don't understand how HEAT works - it's meant to be emulating a console and/or tape machine, so the sound of HEAT should be written to the audio file as its produced, and then played back through HEAT again as its played back? Does skipping it during tracking mean that the audio file doesn't hold the 'HEAT' sound, or just that you're not monitoring live signals 'off-tape' and instead it writes the HEAT signature onto the disk? Or is it just a mix thing and the audio tracks are unaffected, regardless of how many time the audio is passed through?
Dominic
Old 03-17-2021, 09:57 AM
Originally Posted by dominicperry View Post
Thanks Kyle.
Dominic
You can think of HEAT as a plugin with dedicated control sections, which only apply to audio tracks. It can be pre or post the Insert section. But, the processing is not printed to disk during normal operation (it's a mix thing). Printing requires bussing an audio track running HEAT to a second audio track, then recording the processed audio to that second track. You can read more about HEAT here.
Hope that helps.
Kyle Splittgerber
Berkeley, CA
Old 10-31-2021, 02:32 PM
SoundEng1 SoundEng1 is offline
Hi Dominic,
Would be really nice to use Heat for tracking. Oversampling option for Heat would be Awesome. Make it possible!
Old 11-05-2021, 05:32 PM
tekn0 tekn0 is offline
I agree with all of this, I bought a carbon hoping to use HEAT with DSP for tracking. It's such a huge part of my sound.
Old 11-23-2021, 07:58 PM
Keith Moore Keith Moore is offline
This was a MAJOR bummer when updating to Pro Tools HDX with the Hybrid Engine. I’ve always used HEAT with my entire sessions from tracking to final mixes. Now all of a sudden it’s bypassed in tracking mode. Please fix this!!!
Pro Tools HDX 2021.6.0
Lynx Aurora 16
Ross Martin PCM4222
Ross Martin Super Beast
Apple Mac Pro 8 Core 2.66Ghz 16GB RAM
OSX 10.14.6
http://www.keith-moore.org
Old 11-24-2021, 10:47 AM
SomeOtherGuy SomeOtherGuy is online now
Hope that helps.
But when bouncing your mix to disk, the HEAT processed mix is surely included in that final bounced mix, yes?
Pro Tools Ultimate, Avid MTRX, MOM, Mac Pro 3.5 Ghz 6-Core (2014) 128 GB RAM, Mac OS Big Sur, Samsung EVO SSD
Old 11-24-2021, 05:24 PM
Sardi Sardi is offline
Of course.
Kyle was (I believe) referring to tracking with Heat. IOW - it won’t be printed through Heat during recoding to disk.
Still kind of scratching my head as to why Heat is a necessity during tracking.
Old 11-25-2021, 01:48 PM
Hi Dominic,
Hi Kyle,
I’d like to strongly state that this decision was awful. I 100% always use HEAT by default when I start any new tracking session. I sincerely hope AVID with fix this as I’m strongly regretting updating to the Hybrid Engine now.
Lynx Aurora 16
Ross Martin PCM4222
OSX 10.14.6
Carbon Fan Noise Halvo Pro Tools | Carbon 24 10-28-2021 11:27 AM
Carbon with anything other than 10.15.7? Matt Hepworth Pro Tools | Carbon 12 01-08-2021 08:14 AM
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 11:17 PM
