Anyone got patch names?
Hello,
I am wondering if anyone out there has patch names for a Korg X3 and (or) a Roland JV-1010 sound module in XML? The Korg web site no longer shows any record of the X3 because it is too old, and The Roland site has the patch names listed in PDF. Thanks!
Raleigh |
Re: Anyone got patch names?
This isn't xml
But OMS libs for more modern instruments that people uploaded. I believe there is a way to use these OMS libs and convert them to XML (not sure if digi includes a utility for this..or if it will "import" oms docs directly. If need be, open one of the extisting xml libs in a text editor and take a look at it. Pick something "close" to the type of intsrument your wanting to use. Take a look and see what needs to be done. ie..how do they represent bank changes..etc. You can use any text editor..type or copy in your patches and bank change info..then save it with a .midnam extension..and it should work. Here is the link to the uploaded OMS files. http://www.visionsj.com/oms/names.html give it a shot and see. |
Thanks for your help - I'll give it a shot!
Raleigh |
I also need the patch names for MOTIF and for JV-1010 anyone did it already?
Thanks |
Hi
I have a problems with KORG PA80 patch names. I do have TEXT file of all patches but I don't know how to import it to PT LE 5.1. I have only GM bank in OMS names to work with. What should I do for PA80 patches to apear beside GM bank?? Thanks for any advice G4 400, 001 |
In the Acrobat Reader, look for the tool with a "T and a dotted rectangle". Highlight the text you need, copy, paste. Mind you, some PDFs don't seem to offer this facility. Perhaps for copyright reasons? However the Roland ones seem ok. Phil
SoundPunk | Pro Tools Tips & Tricks |
Have fun! [img]images/icons/cool.gif[/img] Phil
Raleigh,
I have the patch names for the X2 that I had to make from scratch. It's the same as the one for the X3 + 1 patch. I can get it to you in jus abou tany format except xml; let me know if you want it. EjA |
Thanks for advice Accession!! It works!
Ground Control patch names = 11R patch names? | drebin | Eleven Rack | 5 | 11-23-2010 12:54 PM |
OMS Patch Names | Tom Pollock | Pro Tools TDM Systems (Mac) | 13 | 07-28-2000 08:47 AM |
PT5 & OMS Names Manager (MIDI patch names) | Baron Von Deca | Tips & Tricks | 0 | 02-17-2000 03:55 PM |
OMS PATCH NAMES? | studiocenter | Pro Tools TDM Systems (Mac) | 2 | 02-17-2000 12:12 AM |
Patch Names on PT 5.0? | studiocenter | Pro Tools TDM Systems (Mac) | 2 | 02-08-2000 07:42 AM |
