  #101
Old 06-23-2020, 05:28 AM
Philthy Philthy is offline
Default Re: Is Pro Tools behind the curve?
RISC usually has less realtime problems
Thanks, well that could be good in the long run then!
Phil Mann
Silk City Music Factory - CT Recording Studio
  #102
Old 06-23-2020, 05:42 AM
Michael Carnes's Avatar
Michael Carnes Michael Carnes is offline
Development Partner
Don't think RISC/CISC has any bearing on realtime performance. It's been a long time since there was a pure RISC chip. The simple nature of the architecture often meant that it took a lot of instructions to get something done that could be accomplished by a single instruction build into a wider instruction word. So a lot of the theoretical performance improvements remained only theoretical.
  #103
Old 06-23-2020, 05:45 AM
Was talking about realtime performance. As you said, performance of processing plugin for 1sec may be more efficient with CISC processors which also need less memory, but for realtime - say one sample - this is closer to real DSP as the instructions are shorter and faster.
  #104
Old 06-23-2020, 07:04 AM
deanrichard deanrichard is online now
I don't know any specifics about writing code for those chips. But I do know that, in the end, the real time performance almost always depends on the skill and expertise of the programmers writing the drivers and low level code needed.
I don't know where Avid's PT engineering team is located any more (a few years back it was said that the code base moved from Ukraine to Poland) and I don't know how much that engineering team knows about writing low level code for those processors, but let's hope they know a lot or can learn quickly.
  #105
Old 06-23-2020, 07:05 AM
The only low level code Avid needs to write are the drivers. Everything else is complied using the SDK they have zero control over. Here is the big difference between Native and DSP plugins, for example; the DSP plugins are compiled using Avid SDK and they can control how to use the chips.
  #106
Old 06-23-2020, 07:10 AM
Development Partner
Certainly true. "Realtime" is a term you have to define for each specific situation. In general it applies to the maximum amount of time a system can take to respond to a stimulus. The stimulus might be a button push, a rising wave in an EKG, etc. When designing a system, you have to determine what that amount of time must be, how long the reaction must take and (ideally) what happens if you fail. So the term may mean one thing in a DAW and another entirely in an automobile. That will guide your code writing and your choice of processor.
  #107
Old 06-23-2020, 02:02 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I'll never forget a Stanford Music Special Interest Group meeting where an Intel contractor slipped up and revealed that the Pentium CPU was actually RISC under the hood. SillyConMan Valley marketing has always been pretty bizarre.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #108
Old 06-23-2020, 02:30 PM
Well they really are CISC to mere mortal developers. Intel has had some bizzare approaches to stuff, like at times seemingly trying to deny the processors were microcoded. (if you acknowledge that then then yes the architecture might look more RISC like). I saw a bizarre spat where Intel developer support was telling us the processor were not microcoded. IIRC we sent them a copy of their microcode update included in an OEM firmware fix with a "what's this then" note
  #109
Old 06-23-2020, 03:01 PM
Development Partner
Heck. Even bits of the 68000 were microcoded.
  #110
Old 06-23-2020, 03:27 PM
Yep it was really bizarre, but they really seemed to not want to talk about microcode for quite a while. In our case our co-founder/architect gave their support folks every clue that we uh might know what we are talking about.. eventually got to a senior person at Intel who was very apologetic for folks wasting our time. We had discovered a subtle CPU bug but noticed it did not happen on all versions of a CPU and then noticed that Intel seemed to have fixed it in some microcode updates that some OEMs had access to.. we'd even unpacked that microcode out of a Dell update. We were just trying to work out how to tell if it was installed/how to tell customer what to do. (... early days of VMware).
EQ Curve spoons Avid S1, S3, Dock and Control App 6 01-10-2017 04:16 AM
X-curve mr.armadillo Post - Surround - Video 0 04-27-2014 04:32 AM
Pro Tools Learning Curve DJKeys macOS 14 07-19-2011 02:57 PM
Learning Curve for Pro Tools from SX or Nuendo Use musicmanz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2005 04:17 AM
How can I see my EQ curve? uno1234 Pro Tools TDM Systems (Mac) 3 08-11-2005 02:15 PM
