M-Powered Lightbridge Limitations
Since Digidesign has decided to cripple PTMP/Lightbridge functionality without explanation, I think it's fair to expect from them some kind of documentation on how PTMP and the Lightbridge are supposed to work together, even in crippled mode. I haven't found any documentation on this, but as far as I can tell, the following seem to be true:
1.) Any interfaces with IO channels numbers on them greater than 18 won't work with PTMP. 2.) Analog outs are always 35 and 36. Therefore, the only way to get them to work is to make them mirror the SPDIF outputs and order the channels so SPDIF channels are first (i.e. make SPDIF channels 1 and 2) 3.) For inputs, ADAT channels are not renumbered based on channel ordering. In other words, you lose channels 1 and 2 of your first ADAT because they now overlap with SPDIF channels 1 and 2. 4.) For outputs, ADAT channels are renumbered based on channel ordering. i.e. the 1st channel of the ADAT 1 is channel #3, the 1st channel of ADAT 2 is #11 and so on. 5.) ADATS 3 and 4 are completely non-functional in PTMP, and can't be used even if you aren't using ADATs 1 and 2. (i.e you can't use ADATs 3 and 4 to solve the conflict with the SPDIF channels outlined above, even if it doesn't exceed the 18 IO limitation.) So, Digidesign, can you confirm that this is how in your view PTMP and Lightbridge are supposed to work? |
Re: M-Powered Lightbridge Limitations
Oh, and one more thing
6.) Because of 3.) and 4.) above, hardware inserts cannot be defined because input and output channel numbers no longer coincide, making HW inserts impossible in PTMP. |
Digidesign - can you please respond? I really need you to confirm whether or not this is how your software is supposed to operate.
Digidesign - I need a response. There is no reason why you can't reply to this indicating how the Lightbridge is supposed to work with PTMP.
Look at the title of this forum/conference: Digi Users Conference.
If you so desperately need an answer from Digidesign, you need to contact them directly. I would suggest by phone.
There's certainly nothing wrong with posting this here. After all, other Users probably need the same info, since the functionality changes from release to release, and isn't documented anywhere. |
Suggesting that you contact Digidesign directly was something that was supposed to be useful to add.
Posting the same question over and over again trying to get a response from Digidesign hasn't seemed to be working out for you, mostly because, as I pointed out, this is a user's conference. Maybe stomping your feet and holding your breath might get better results?
Digidesign tech support reads this forum and posts here, and there's no reason why they can't document the functionality of their product so everyone can understand how it works. |
If they have time, they will read and post here. Which is, again, why I made my recommendation. They may not even read your desperate plea for a response for days, let alone respond (here, at least) in a timely manner. I know this from spending WAY too much time on this board; I am very familiar with the frequency of Digidesign Tech Support posts, and my suggestions are truly meant to assist you in your quest for an answer to your question. If you need/want response from Digidesign Tech Support in the immediate time frame that you apparently desire, then you should take my advice and contact Digidesign Tech Support directly.
Digidesign - your paying customers need an explanation. Why is it so important for you to disable more than 18 I/O's that you would ruin the ability to do hardware inserts in the process?
M-Powered Essential editing and automation limitations | Metallising | Pro Tools M-Powered (Win) | 0 | 09-12-2010 06:27 PM |
M-Powered and Profire Lightbridge?? | bassface74 | Pro Tools M-Powered (Mac) | 8 | 05-30-2008 12:21 PM |
M-Powered Academic Limitations? | snahster | Pro Tools M-Powered (Mac) | 1 | 09-11-2006 05:01 AM |
lightbridge, m-powered? | will the moor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-16-2006 03:04 AM |
M-powered Limitations? | etherealproducer | Pro Tools M-Powered (Win) | 2 | 04-17-2006 10:01 PM |
