Old 08-11-2005, 04:51 PM
Leyenda Productions Leyenda Productions is offline
Default How to build a miX System?
Hello guys like i said earlier i'm new to this forum and protools, i have a digi 002R and i was wondering what types of cards and interface would i need to make a mix system?
like what do i need a mix core and a farm card and that's it? or do i also need an interface? and is the mix system still being supported by digidesign?
i want o do this on a PC.
if you guys please be so kind and give a list of what exactly i need to get one going thanx......
thanx in advanced for your help.....
www.LeyendaProductions.com
Old 08-12-2005, 08:50 AM
siimlane siimlane is offline
Default Re: How to build a miX System?
Well...
Minimum setup would be Mix core and one 888 interface. That gives you 8 channels of analog or digital I/O. If you need more processing power then add farm cards and if you need more I/O then add second interface with Y- cable. Basically that's it.
Old 08-12-2005, 07:29 PM
thank you so much for answering.
now how many tracks can i get with let's say a mix core card and 2 farm cards?
also does it support OSX?
up to what version of protools can i use?
and can i use the mix system on a PC?
thanx..
Old 08-12-2005, 09:23 PM
steve at Your Heaven steve at Your Heaven is offline
Two places on the Digi website will give you much information about the discontinued Mix systems:
http://www.digidesign.com/compato/xp/mix/
and
http://www.digidesign.com/products/mix/
You can also probably download the 6.4.1 manual, which should tell all.
steve
Your Heaven
Old 08-13-2005, 01:46 AM
Rock_Artist Rock_Artist is offline
Track Count is from 64 voices and upto 96 or so (I don't remember well the Mix/TDM limits ).
(Check the 6.4.1 manual)
If I remember like HDs the trackcount barrier is core+mix farm. (any additional DSP simply gives more cpu but not voices, on HDs it's HDCore+HDAccel)
OS X...
You can work with Panther on G4s.
However G5s or Tiger are not supported.
On PCs however you enjoy faster cpus (though not officaly supported by Digidesign) & the Windows XP.
For Mix systems the Windows platform will give you more native processing which is great for Mix systems....
Just keep in mind that it'll be wiser to invest in HD rig because Mix TDM is discontinued so you're pretty much stuck with what they've got now.
Except of the track count the features you have compared to LE series aren't worth it for anyone...
Just wanna do music,
RA.
Need help with New System Build Fireball71 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-04-2009 09:26 AM
My System Build JMonroe24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-27-2008 11:58 AM
New PC System Build! dowtish01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-13-2008 08:08 AM
It can be fun to build your own system. filmixer Pro Tools TDM Systems (Win) 0 07-30-2005 06:52 PM
What do you think of this system I might build ikon1234 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 04-18-2004 06:43 AM
