Old 10-03-2024, 02:59 AM
Captain Al Captain Al is offline
Default EUCon crashes when closing Logic 11
Had this since the last update, EUCon crashes occasionally when I close Logic. Met someone yesterday that has exactly the same thing, I've reinstalled it several times.
Any chance of getting this fixed? can send a full crash log if needed.
Crashed Thread: 34 EuDOF SM:EUCON_Node_Browser-EUCON_Node_Browser 25-AC-C3-DB-7E-
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000000c5
Exception Codes: 0x0000000000000001, 0x00000000000000c5
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [1912]
VM Region Info: 0xc5 is not in any region. Bytes before following region: 4302552891
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
Old 10-03-2024, 06:00 AM
tope d's Avatar
tope d tope d is offline
Default Re: EUCon crashes when closing Logic 11
let me check quickly then get back to you...
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 10-03-2024, 06:05 AM
tope d's Avatar
I've found a previous bug which has a fix that improved performance and reduced the occurrence of the issue. It was tracked under Bug number GWSW-17161
The bug has been closed and Eucon version was released back in the first quarter of this year.
May we know what version of Eucon you're currently on and what control surface you're using?
-Tope
www.topedomingo.com
Old 10-03-2024, 06:25 AM
Wow super fast reply thanks, Ahh sorry I should have said, its the last one released at least that's on my Avid download links.
I'm using an MC Mix & MC Control
Version 2023.11.0.121
EUCON Version 4.17.2.121
Old 10-04-2024, 07:31 AM
EddieJones's Avatar
There are two parts to this issue, one on EUCON side and one on Apples. We have fixed the EUCON side for EUCON 24.10 coming soon. This makes it 90% better! Apple have been informed about the other part so should add this into Logic as well.
Old 10-04-2024, 07:34 AM
That's great news Eddie, what amazing support! Thank you! yea I spoke to Apple they know about it. Fingers crossed for a fix soon. It's a pretty regular crash, dunno if that makes it any easier to fix :)
Old 10-10-2024, 07:43 AM
ziggidybang ziggidybang is offline
I have the same issue, I'm using an S4 and it's pretty much unusable every time I select anything on a channel strip or track.
any idea when this new update will be released from avid?
Old 10-18-2024, 09:35 AM
EddieJones's Avatar
I'm hearing reports that Apple fixed it in Logic 11.0.1....anyone running that version can confirm?
Old 10-23-2024, 07:37 AM
Yore Yore is offline
I got this error on Logic Pro 11.0.1 few days ago. I'm on old Eucon software version. I guess the EUCON 24.10 has not been released yet?
Old 10-23-2024, 09:00 AM
EddieJones's Avatar
Not yet a couple of weeks hopefully.
EUCON/Logic Pro X 10.6.3 Crashes tacsutdios Avid S4/S6 2 04-18-2022 05:08 PM
Logic X 4.1 Crashes Regularly because EuCon dawand Artist Series 6 03-19-2018 09:19 AM
Top|Back not closing plugin like Eucon 3.6 ripekeai Avid S1, S3, Dock and Control App 5 11-03-2017 05:43 AM
Does S6 install Eucon/Eucontrol ? Logic crashes... vudoo Avid S4/S6 5 05-03-2016 10:46 AM
PT 10.3.8 Crashes after closing session drvibb Pro Tools 10 2 03-20-2014 03:17 PM
