Old 01-27-2009, 11:52 PM
Heck Heck is offline
Default What's the correct way to save plug-in maps in PT 8?
Ok, so I assigned a bunch of parameters using "Learn Midi CC" with my Axiom controller. The problem is that none of those settings load the next time I bring up the plug in, so far I've been trying to do it with Xpand.
I tried "Save Map As" and setting it to default but no luck. I've also tried saving it as a preset in hopes of finding a solution but no luck there either.
I had all of this set up nicely on 7 but can't seem to figure out on 8. Anyone have any ideas?
Old 01-28-2009, 12:01 AM
Default Re: What's the correct way to save plug-in maps in PT 8?
You've got to be kidding me.
I just saw this on the AIR blog
"The 'learn midi cc' function in plug-ins allows you to map a fader, knob or other midi controller to a parameter in the plug-in. This setting is saved with the session and cannot be saved as a preset or mapped to other plug-ins. For instance, if you have an instance of Boom open and map a knob to one of it's parameters, then open another instance of Boom, you would have to re-map the controller to the new instance if you wanted to control it. You cannot save the setting and apply it to another instance of the plug-in."
Come on Digidesign, REALLY? How do you overlook something like this when your trying to become a player in music production? This is a disgrace. Wow.
Old 01-28-2009, 10:11 AM
DigiTechSupt's Avatar
We didn't overlook it. To be able to save plug-in maps, you need to have a compatible control surface - the Axiom is not one of them. The reason for this is that the way these communicate with Pro Tools requires specific functions as defined by a controller layer in the hardware and only certain hardware can support it.
If you use a compatible control surface (the new Axiom Pro will allow this), you'll be able to save and recall your plug-in maps.
Avid Audio Tech Support
Support FAQ
Old 01-28-2009, 10:29 AM
RussUK RussUK is offline
You're getting confused DTS, this isn't an issue with the controller keyboard but it's to do with the implementation of the plug-ins within PT, you cannot save the CC maps of a plugin within the plugin ONLY the session. There's a workaround on the blog, but it would be good to have this implemented. Not a bug as such, more of a wish list.
I work with amazing people who do incredible things.
Founder of the Expert Sites.
Old 01-28-2009, 06:16 PM
the way these [Control Sufaces] communicate with Pro Tools requires specific functions as defined by a controller layer in the hardware and only certain hardware can support it.
So at a guess DTS, to de-couple Pro Tools from the controller layer wouldn't be in Digidesign's best interest?
filosofem
Old 01-29-2009, 12:02 AM
filosofem
No more than you working for FREE
Old 01-29-2009, 09:43 AM
RussK thanks for the workaround, I thought about it but was secretly hoping that wouldn't be the solution. This sucks majorly, I hope it's fixed in the next upgrade.
Old 01-29-2009, 10:50 AM
If it could have been done this way currently, we would have. Believe me - I asked the same question, because I thought it was pretty...silly not to be able to do this, but there's a technical reason for it. Let me see if I can dig up the email that explains it...
Support FAQ
Old 01-29-2009, 10:51 AM
Can you explain what you were doing in PT7 that was working??
Support FAQ
Old 01-29-2009, 11:09 AM
I would assign the parameters and save settings as. Then every time I loaded an instance of say Xpand the same knobs, buttons and sliders on my controller would be assigned.
This guy demonstrates it on youtube.
http://www.youtube.com/watch?v=I2lOq_xIc-Y
HELP!! Can't Import Multiple Midi Files W/ Tempo Maps -Meter Maps kfoody Pro Tools M-Powered (Win) 0 09-26-2011 08:08 AM
Save session copy as no longer changes unique IDs, correct? drguitar Post - Surround - Video 2 08-02-2010 03:41 PM
D-Command Plug-In Maps creativecontrol ICON & C|24 3 05-31-2009 01:23 PM
Saving Plug-In Maps PT 8, Bug??? SBR1710 Virtual Instruments 0 12-30-2008 08:30 AM
Plug in maps wont save??? PT 8 SBR1710 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-28-2008 08:40 PM
