best CD burner for use with SCSI64 and Masterlist??
I have the ATTO SCSI64 card and have just purchased Masterlist. Which approved CD Burners will plug into the 64 pin cables supplied with the SCSI card ???
Thanks |
Re: best CD burner for use with SCSI64 and Masterlist??
I would suggest the Glyph Plextor. You'll need to by their SCSI2>50pin Centronic Cable. That drive rocks with MLCD. Never had any errors.
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
thank you kindly marvin
I shall have a looky into it |
Francis,
I also like Plextor. I have an internal 12x Plexwriter connected to the SCSI64 card in my G4. Works flawlessly. Good luck.
iMac i7 2020 Monterey 16GB HD Native Thunderbolt |
audiaudio,
forgive my ignorance but do youmean you have that fitted instead of your apple supplied CD-RW/DVD?? does the SCSI64 have an internal SCSI plug?? thanks, francis |
Originally posted by francis eyre:
do you mean you have that fitted instead of your apple supplied CD-RW/DVD?? Yes, I removed the original drive and replaced it with a Plexwriter. does the SCSI64 have an internal SCSI plug?? The dual-channel SCSI64 card has two SCSI ports. I've connected the internal Plextor 12x to one port and an 18GB Digidrive to the other. Works well. Hope this helps.
thanks very much
masterlist-cd burner | deerwomon | Digidesign Hardware & Software | 6 | 06-11-2002 09:39 AM |
Mac IIci and Masterlist 1.3 CD burner | safeasmilk | Digidesign Hardware & Software | 0 | 06-06-2002 12:34 AM |
can't use masterlist or jam with my burner | fikafer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 06-20-2000 11:53 PM |
Can masterlist run on G4 Usb or Firewire Burner?? | soul angel | Digidesign Hardware & Software | 1 | 05-05-2000 12:20 AM |
Can masterlist run on G4 Usb or Firewire Burner?? | soul angel | Digidesign Hardware & Software | 0 | 04-30-2000 09:33 AM |
