Digi Please Help! TL SpaceV8 Not showing pictures
I just install the Music Production Toolkit 2 v8 and the TL Space Native is not showing any pictures (inside the plugin), what can I do? Thank you for your help in advance.
Re: Digi Please Help! TL SpaceV8 Not showing pictures
Where are you loading the presets - from the left hand panel or from the RTAS drop-down menu in the upper left?
If it's the latter, that won't show the images, as they are not 'linked' to the actual presets on the right. If, on the other hand, you're loading from the preset menu on the right, then something is wrong and you might want to try trashing preferences for both Pro Tools and TL Space and see if that fixes it. |
I just restart the computer and everything is working fine.
Thank you for your support. |
I see the Browser - on the Right, with the Load and Edit buttons. I also see the Presets drop-down - which saves my settings, like all (or most) plugins. And I see an RTAS button, just below the BYPASS button - which does nothing when I click it. I've been using TL Space for years, and have always and only selected/loaded IRs from the Browser window - and have always seen the images that go along with them. But suddenly MOST of the images don't show. When I look in /Library/Application Support/Trillium Lane/TL Space/Impulse Responses/01-Halls/Factory (for example), I can see the .jpg associated with PA-horn-in-hall, but when I load that IR (from the Browser, using the LOAD button) the image does not appear. But if I select Concertgebouw, the image shows as expected. I just removed and reinstalled TL Space - no change. Suggestions? PT 9.0.2, TL Space 8.0cs3
Ron Stephens [email protected] Latest Pro Tools Studio, macOS 14beta, Mac Studio M1. |
Bump. Hoping for some clarification on this.
Digi 002 is not showing up? | emcicle | macOS | 8 | 03-20-2012 06:03 AM |
DIGI 003 rack not showing in inputs | xterraguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-05-2011 09:23 PM |
TL Space v8 Pictures not showing | Choral14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-24-2009 10:44 PM |
Digi Desktop Pictures-Update? | Armando | Pro Tools TDM Systems (Mac) | 4 | 08-12-2008 03:09 AM |
digi 001 not showing as an in/out *DELETED* | denniso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-17-2007 10:25 AM |
