Mono Tracks Turned into Stereo Output by Plugins
While the recorded information on a track shows mono still...two panning knobs appear when adding a stereo plugin.
I assume the left and right pans control the left and right channel "volume" and don't really move the audio from one side to the other? If I want the both sides of stereo field to be more to the left of center what is the right way to set these? I'm sure playing with them will yield answers, I just want to make sure I understand what's really going on. THANKS! |
Re: Mono Tracks Turned into Stereo Output by Plugins
Yes after mono-to-stereo plugin the output is stereo and by default panning is fully open (hard left, hard right).
You can restrict this stereo field in numerous ways, but let's say you want same thing as -50 from mono channel, I would first try setting left to hard left and right to center. That is half way to left in stereo panning. If the image is still too wide you can bring the pan pots closer together with both pots at -50 being mono image (wondering why you would want to do that as you used mono-to-stereo to begin with).
That's the reason you will see the two Pan Knobs, although the source of the Track (input) is a mono signal. Regarding panning, it works the same as with any Stereo Track. The left Pan knob pans that left channel between the left-right output bus, and the right Pan knob pans the right channel of that Track between left-right of the Output Bus.
Edgar Rothermich Author of "Pro Tools 2020 - How it Works" from the Graphically Enhanced Manuals (GEM) series http://DingDingMusic.com/ YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/ |
Copying plugins from stereo tracks to mono | MusicMadness | Pro Tools 2018 | 7 | 03-31-2019 06:49 PM |
Plugins Aux track Output Stereo or Mono? | soundartsonline | Pro Tools 11 | 3 | 02-15-2016 04:45 PM |
A question about mono/stereo plug ins on mono tracks. | rockguitarist1255 | Pro Tools 10 | 2 | 12-24-2011 07:33 PM |
Stereo tracks to single mono output... what's happening? | PTPerson | Pro Tools TDM Systems (Mac) | 4 | 02-22-2011 02:39 PM |
Stereo Output Not Working on Mono Tracks | amoeba7 | Pro Tools M-Powered (Mac) | 0 | 04-21-2007 08:59 PM |
