Old 12-03-2011, 12:10 AM
andresumana andresumana is offline
Default problems with the expansion pack codec
I tried to install my pack expression but no activation codes are valid, I have read here in the forum, I found an email address, e-mail I waited a week and have had no response, I'm pretty disappointed in the support system Avid. I hope to help resivir here, I live in Sweden and is a bit conplicado for me to call USA that do not speak English.
Old 12-03-2011, 01:03 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: problems with the expansion pack codec
Är du på Windows eller OSX? Om du har Internet Explorer 9 installerat måste du avinstallera den innan du kör ERXP.
Efter din Elva Rack är uppdaterat kan du installera IE9.
Kontrollera att du är ansluten till internet. Se till att dina drivrutiner för de elva Rack är installerade.
Om du fortfarande inte kan installera, så du måste ringa Avid för att få detta problemet löst.
Are you on Windows or OSX? If you have Internet Explorer 9 installed, you need to uninstall it before running the ERXP.
After your Eleven Rack is updated you can re-install IE9.
Make sure you are connected to the internet. Make sure your drivers for the Eleven Rack are installed.
If you still cannot install, then you will have to call Avid to get this issue resolved.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
problems with AVC codec videos viaspiaggia Post - Surround - Video 34 06-12-2013 07:49 PM
expansion pack pinnacle Pro Tools 10 1 09-05-2012 05:46 PM
please help, problems with the 11r expansion pack download aerdelee Eleven Rack 2 04-05-2011 01:16 PM
ACE MEGA CODEC PACK issue harbong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-02-2006 11:56 AM
5.3.1. compatibility problems with Quicktime codec glenbo Post - Surround - Video 4 05-18-2005 02:45 AM
