The track "guitar" is unable to perform Elastic Audio because an audio file on the...
Hello my friends, I recently upgraded to bigger hard drives and cloned my files to the new ones using CCC and now I get these errors when I try to open a session:
The track "march" is unable to perform Elastic Audio because an audio file on the playlist is unsupported for Elastic Audio processing as it is read only. This track Will be made in active. The air must be corrected before the track can be made active again. I checked the file and it was read/write so I don't know what's going on. I'm using a quad core Mac Pro with OSX 10.6.6 and Pro Tools 8.0.5. Any help is greatly appreciated.
Tampa Recording Studio |
Re: The track "guitar" is unable to perform Elastic Audio because an audio file on th
Repair Disk permissions?
I tried that, but no luck.
Fortunately, I still have the original drives and they do not have this error, but I still need to upgrade to larger drives as I'm running out of space.
First
Which drives were replaced? So there was no need to use CCC on the record target drive. I know because I just upgraded my internal spinner to a SSD. Now the OS drive yes needs to be listed as having a MBR installed (via CCC) But your target doesn't. The reason I ask is because CCC has different kinds of options when copying - I would wipe the new drive, manually formatting to MAC osjournaled. And then manually copying the sessions you want to the new recording target drive. You also want to double check the disk allocation for the session after you get it loaded up to make sure it's looking at and recording to the new drive name/number
I was just going to say to check the allocation in Pro Tools not just on your mac info panel.
Dave Cournoyer-guitarist-project studio Mac Mini late 2012, i7, Sierra 16GB PT10.3.10HD PT12.5.2 Apogee Mini-Me firewire. |
Elastic audio is unable to perform error | Rwilliams0190 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-18-2020 02:24 AM |
AudioSuite results in "unable to create a new audio file on drive" | gorgon | Pro Tools M-Powered (Mac) | 7 | 07-30-2017 03:35 PM |
"Unable to locate M-AUDIO Hardware" - Fast Track, PT8.0.5, Win 7 | JimGriffith | Pro Tools M-Powered (Win) | 6 | 10-23-2014 07:35 AM |
PT 10 "Unable to parse audio file" error | matt-o- | Pro Tools 10 | 3 | 04-07-2014 10:19 AM |
"unable to parse audio file" and "OSStatus Error -208" ! | reichman | Post - Surround - Video | 2 | 03-22-2010 04:46 AM |
