Old 03-28-2002, 11:33 AM
3rdstory 3rdstory is offline
Default Can\'t open song, need help with cryptic message
After a year and a half of researching the field and pouring over the posts in this user conference I finally purchased Digi 001 / PTLE. So I'm a newbie here, about a week into getting to know the system. Most of the time I'm smiling - PTLE is so logical and well laid out I wonder why I waited so long.
But last night, after multitracking on a song for a couple of hours - I was having a great time - I quit the song. About ten minutes later I tried to open up the song. I was not able to.
When I went to open a song, it started to load, with a small window rapidly displaying progress and the files it was loading. When it got to the file "Audio 1_O6" loading ceased and a window appeared asking to find Audio 1_06. I
located this file. It was right where it should be.
There were several buttons one could select. I chose OPEN. Then a window appeared with this message: "Audio 1_06 has too few samples. Regions referencing missing samples will be dropped from the regions bin. Do you want to continue?" What does this mean? The choices in this window were YES or NO. It didn't matter which choice I made, they both took me back to the window asking to locate Audio 1_06, and the song did not open. It had me going in circles.
Other buttons in the window asking to find Audio 1_06 include SKIP and SKIP ALL. SKIP did not appear to do anything. SKIP ALL opened up the song, but all the data in each track was missing, except the data in track Audio 1_06.
The result is that I cannot open up this song. Also, all of my automatic backups (about five of them) produce the same results. (so much for backing up) Bummer. Is the song lost? Corrupted? Is there a way to retrieve it? I don't mind losing Audio 1_06 but I'd rather not lose the whole file.
Comments and solutions most welcome. Thanks.
Old 03-28-2002, 03:21 PM
michael verdes michael verdes is offline
Default Re: Can\'t open song, need help with cryptic message
this is a problem i have delt with several times. do you have multiple drives or have you imported audio from another session
Old 03-28-2002, 06:14 PM
soundboy69 soundboy69 is offline
Location: From: Trinidad (Humboldt Co.); living: somewhere between Chicago and St.Louis...
-Hello.
Hmmmm...wow. Incredible suckage!
Does anyone out there in PT's land know what this is all about. I've never ran into this one? [img]images/icons/confused.gif[/img]
soundphaRm
Old 03-28-2002, 10:35 PM
Chompers Chompers is offline
The message is telling you that you are opening a file that has the same name but isnt the file. OR, an older version of the file that has been changed somewhat.
THis illustrates the importance of naming the tracks before you record them.
There are so many nightmare scenarios that can be avoided by naming the tracks first.
Old 03-29-2002, 08:56 AM
Michael - Yes, I have two drives. The internal drive that came with the G4, and an external Glyph firewire drive. The Glyph is my audio only drive. Why is this important? Have you any advice about dealing with this problem - is there a way to open up this file? Just to hear that someone else has experienced this gives me hope.
Chompers - your comment about naming tracks right away is well taken. I will make this a part of my recording procedure from now on. Just curious, why does this help?
Thanks.
Old 03-29-2002, 10:39 AM
DigiTechSupt's Avatar
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by 3rdstory:
The Glyph is my audio only drive.<HR></BLOCKQUOTE>
What utility did you use to format your FireWire drive?
For best results, format FireWire drives using the Mac OS:
-Disable all non-Apple FireWire Extensions and restart the computer (very important).
-If the drive is raw, not yet initialized, just power it up and plug it into the Mac. The Mac will throw a "Unrecognizable drive..." dialogue and ask if you want to eject it or initialize it. Initialize it.
-If the drive is already initialized with something else, do the same thing...plug the drive into the Mac and then choose "Erase disk" from the "Special" menu.
Of course, this will destroy any data on the drive so back up first if necessary.
NOTE:
For all FireWire compatibility information:
http://www.digidesign.com/compato/firewire.html
Brent
Avid Audio Tech Support
Support FAQ
Old 03-29-2002, 11:45 AM
Digi - Thanks for your reply. How does your information regarding drives relate to my problem of not being able to open up a particular file? I'm missing something here.
[If the drive is already initialized with something else, do the same thing...plug the drive into the Mac and then choose "Erase disk" from the "Special" menu.]
After I did this, and then re-installed my files onto the Glyph drive, would I then be able to open the file I want to open, without any "error" messages?
Old 03-29-2002, 11:53 AM
daryl bowden daryl bowden is offline
Well, as you said in your initial post you don't mind losing that track. If that is the case, choose "skip" when it asks you to find the file and the sesssion will load sans audio1_06. I have had this problem too before and I have followed digi's instructions to the "T". It doesn't happen often, but when it does its a real pain in the ass. I think it is a bug, though, because it's as if the file just disappears when you know it was there 10 minutes ago. Welcome to the wonderful world of technology, ain't it grand!
Check my group out at: www.mp3.com/the_sons_of_edison
Old 03-29-2002, 03:51 PM
3rd Story: this is a problem i have had 100 times before. I have an iternal drive and an external Glyph. there are a lot of problems you can run into when you have 2 drives. tell me what you are doing and how you are using the second drive. i sure i can tell you the answer.
Old 03-29-2002, 05:54 PM
Michael - Thanks so much for the offer. I tried to email you direct with more detail. Couldn't. Is your email address different than the one posted here?
song will not open, could not complete the open session commandbecause...while transl SNAPPER Pro Tools 9 6 02-11-2017 11:32 AM
song won't open in pt8 SNAPPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-22-2009 11:30 AM
Song Stops every time at :57 - 9128 error message dts.music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-13-2007 01:16 PM
getting a song to open Cam9021 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-17-2007 07:39 AM
Cryptic routing problem with C24 and 192 Nils Groth Pro Tools TDM Systems (Mac) 6 07-09-2007 01:05 AM
