Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 08-16-2024, 07:45 AM
RickT RickT is offline
Default Looking for an interface that works with Pro Tools 5.1
I have an old Mac OS 9 system with Pro Tools 5.1 on it and I'd like to listen to some of my older recordings but I can't find any info on an interface that will work with PT 5.1
I bought a used Digi 002 not realizing that it was for Mac OS X and above.
The Mac OS 9 computer I have has mix cards #1 and #2 installed and connected to a Digidesign Adat Optical 24 Bridge and the Mac has firewire ports.
I realize I can convert all the PT 5.1 sessions over to my Windows PT PC but that would take an eternity. I would like to hear the sessions first before converting them over so I can pick and choose.
Any ideas on interfaces that would work on this setup?
Old 08-16-2024, 08:06 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Looking for an interface that works with Pro Tools 5.1
Original mBox or Digi001, unless you go for card based TDM system. Actually Digi001 is also card based, but without TDM.
Janne
Old 08-16-2024, 10:24 AM
JFreak's Avatar
Sorry, read your post too fast as it was in the USB/FW subforum. Short answer:
  • There is no FW interface that will work on OS9
  • If you need USB, your only choice is original mBox
  • You already have an interface. If you need DA, buy 888|24
Janne
Old 08-16-2024, 10:41 AM
smurfyou smurfyou is offline
Doesn't the ADAT bridge have a stereo analogue out? I forget how you assign it but you should be able to use that to monitor. Just save a copy of your session before you change the routing or anything.
~Will
Old 08-16-2024, 12:23 PM
Thanks for the reply and info J.
So just to be clear if I purchase an Mbox original. I would plug in the spdif ins and outs from the Digi Adat Bridge to the Mbox spdifs and then set the playback engine in PT to Mbox Spdif (assuming that PT recognizes the Mbox)?
Windows 10 - Pro Tools 2018.12.0 - Quantum 2626 - Axe-FX III
Old 08-16-2024, 12:31 PM
You're right. The ADAT bridge does have analog outs in the back. In my PT sessions I have output set to the only non grayed out option which is 1-2 (Stereo). Still no audio out of the ADAT's analog outs.
Old 08-16-2024, 12:39 PM
JFreak's Avatar
No, it is either TDM system or mBox. If you buy mBox you actually need to remove the cards.
Janne
Old 08-16-2024, 12:42 PM
Okay thanks! Honestly I just need to hear the sessions I created years ago. I don't need to do anything other than that. Not sure why the ADAT interface analog outs aren't playing audio.
Old 08-16-2024, 01:25 PM
JFreak's Avatar
They should mirror whatever goes to digital outputs 1-2
Janne
Old 08-16-2024, 01:41 PM
I went ahead and got a used Mbox Original from Reverb. Well see how that goes. Thanks for the tip on removing the Mix cards on the Mac
Recommendations for a interface that works well with PT Sebastian_SAE Third Party Interfaces 4 03-24-2020 10:11 AM
Pod XT as a PT 9 Interface - works. acmost macOS 6 12-31-2010 04:42 PM
pt only works when i only have hd and interface on the mobo chazzo03 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-14-2008 05:29 PM
midi interface USB for Laptop what works? djd2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-23-2005 08:08 PM
MIDI Interface that works with Digi 001? Reg. MIDI 4 10-10-2005 02:45 AM
