Half Speed Record revert to normal speed?
If i record something at half speed, is there anyway to bounce the audio as it is in actuality or not half speed?
i accidentally recorded some stuff half speed, and need it normal. |
Re: Half Speed Record revert to normal speed?
Easy. Let's say you recorded at half speed in a 48kHz session, create a 96kHz session and import the audio without sample rate conversion, the audio will play back and fine. Then you can export it and set the sample rate to whatever you need. There are other ways also.
Edit: I'm sorry. I got that wrong. Backwards. upside down. I'll just leave it to my DUC friends to correct me.
Mac mini M2 Pro 32/512. MacOS 13.6.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1. |
I'm going to try this
Should it introduce any artifacts recording at half speed? |
I think you should just use elastic audio (look it up) and change the length of the clip. Edit: Just use the "Time Shift" plugin in the Audiosuite menu.
So it seems to be introducing some pops and clicks ?
im wondering if this has to do eith my pro tools version? pro tools 2022.5 i recorded everything on a pro tools 11 computer |
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
Yea, thought someone had altered the record command to Shift command space, but it was an other issue
We get this from time to time, people asking for help, then later saying; 'forget it, I found the solution'. I expect it's most often because the poster found it was a mistake on his part, and is embarrassed about it…
Just do this:
1. Switch elastic on the track, use Varispeed : https://duc.avid.com/attachment.php?...1&d=1676204373 2. Get the Elastic Properties page up : https://duc.avid.com/attachment.php?...1&d=1676204373 3. Change the TCE factor from 100% to 200% : https://duc.avid.com/attachment.php?...1&d=1676204373 Your audio will now be running at the speed you recorded it at. |
Personally, I tend to use Elastic Audio for something more natural which requires slowing down during recording. Put all tracks in EA poly and tick based. Reduce the tempo to something that helps you nail the performance, for example from 108 BPM to 98 - 88. Once you have it, check at full speed and tweak any EA parameters as required to avoid any stretch marks and edit the takes are required. Stephen
can you record in at half speed | sbag | Tips & Tricks | 7 | 01-15-2013 10:37 PM |
Half Speed Midi Record | MoreMolecules | MIDI | 0 | 09-29-2008 12:27 PM |
shortcuts for half speed +dbl speed recoring | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-09-2003 02:48 PM |
Half-speed record? Automation | summersleep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 06-08-2003 09:34 PM |
Is there any way to record at something other than full or half speed in PT? | PUCK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-11-2002 12:10 AM |
