Old 02-26-2016, 06:17 AM
Carl Kolchak Carl Kolchak is offline
Default Hidden Feature?
Most of you will know that if the Delay Compensation "Dly" indicator, in the edit window, turns red, you can hover the mouse over it, and it will track down any potential feedback loops.
I was just using that function to see where I'd done something stupid, and accidentally right clicked on that "Dly" indicator, and a menu pops up :
Meters
with the options to check :
Bus
Input
I can't find any documentation on this feature, and as far as I can tell, it doesn't seem to effect the way Delay Compensation is reported (i.e. "Metered") in either the mix window DC fields, or have any obvious bearing on the I/O set-up.
It also doesn't appear to effect the actual mixer meters (assuming my initial interpretation of "Meters" / metering / metered was incorrect, and it was literally the mixer meters being referenced).
Of course, if nothing is going wrong, then I probably wouldn't see any change in behaviour, so this is probably a wild goose chase.
Anybody know what this function does, and where to find the relevant documentation?
Cheers!
Another hidden feature??? jre3132 Pro Tools TDM Systems (Mac) 3 05-10-2007 01:48 AM
Hidden feature? Farmer Dave Pro Tools TDM Systems (Mac) 5 09-15-2006 08:17 AM
feature req.: hidden status visible in import Frank Kruse Post - Surround - Video 3 08-25-2006 11:13 AM
Hidden Tracks Scoobster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-30-2003 09:44 PM
Roland SRV-330 hidden feature? Joris de Man Tips & Tricks 12 07-27-2001 10:42 AM
