Old 12-25-2014, 06:46 AM
alchemyy alchemyy is offline
Default Elastic audio problem
I'm a newbie. I'm trying to use elastic audio in Pro Tools 10. After the track is analyzed, when I go to analysis view or warp view, there are no transient markers. I've tried monophonic, polyphonic, and rhythmic on a number of different kinds of tracks. I have watched numerous tutorials. In all of them, they have transient markers in the track after it is analyzed. Any help would be appreciated.
I use:
Windows 7, 64 bits
500 GB HD
4 GB RAM
Presonus Audiobox USB
Pro Tools 10 HD
Old 12-25-2014, 10:55 AM
mesaone mesaone is offline
Default Re: Elastic audio problem
Select the clip. Go to Clip > Elastic Audio Properties and adjust the Event Sensitivity.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 12-25-2014, 11:25 AM
Thank you for the attempt but there're sill no transient event makers.
Old 12-25-2014, 11:26 AM
Michael Zull Michael Zull is offline
When you first turn EA on it puts the analysis markers in (the grey/black lines in warp or analysis view) but not any warp markers. To change them into warp markers manually, in warp view with either the grabber or smart tool, hover over the analysis marker until you see the double-arrow <-> and double click. Now you should see the blue triangle marker on the bottom of the analysis marker and be able to start warping the audio. You can also Shift+Click a marker to create warp markers on the one you click and the ones just before and after it.
Alternately, if you plan on quantizing the audio you can select the regions and use the Event Operations window (Event drop down menu > Event Operations > Quantize or Option+NumPad 0) to do so. When PT quantizes the regions it will create the necessary warp markers in the process.
screenshot of the edit window?
Old 02-14-2015, 08:35 AM
stevegalante stevegalante is offline
That's what I am expecting normally, but in my case it also puts some (unwanted) warp markers... why ??? If I try to delete them it changes my waveform timing
I'm on PT 10 HD on MacPro / mavericks
http://www.stevegalante.com
elastic audio problem edwallace Pro Tools 10 1 03-01-2013 09:21 AM
Elastic Audio Problem RobinWinjil Pro Tools 10 11 06-18-2012 05:11 AM
Elastic Audio problem clausiii Pro Tools M-Powered (Mac) 4 02-17-2010 02:26 AM
Problem in Elastic Audio (LE 7.4) brentrains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-06-2009 09:24 AM
elastic audio problem harryk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-21-2008 02:20 PM
