  #7141
Old 03-29-2024, 02:05 PM
CEMusic CEMusic is offline
Default Re: i7 Builds - Specs and Results
Originally Posted by EGS View Post
Does that MB have Thunderbolt 4/USB 4? For that CPU/RAM build, you can skip the GPU (!) & spend that money on a bigger 4Tb internal NVMe drive and partition it.
The two TB4 ports were one of the reason for choosing this board.
  #7142
Old 03-29-2024, 02:10 PM
Originally Posted by Skwaidu View Post
I would always keep the OS on it's own physical drive.
Like I said on GS, the build looks quite good, although upping RAM to a mid-level higher XMP one is something I would do.
I would also get a separate GPU myself if only to drive 3+ screens, but it doesn't need to be fancy.
The system will be delivered as whole. I am ordering at www.mifcom.de.
I had selected a different RAM (6000 MHz) but their configurator said it conflicts with the chosen cooler. This was the only one that didn't give me a warning.
Does that system require a liquid cooler or do you think its not neccessary?
Is the Fractal Design Define 7 XL Case alright? Anything regarding cooling in that configuration that needs to be taken care of?
I probably won't need anything bigger than those SSDs. System and Audio will be on separate drives. I may consider a dedicated graphic card later. I am using 2 monitors right now and can't see that changing any time soon.
  #7143
Old 03-29-2024, 02:21 PM
Skwaidu Skwaidu is offline
I have the Fractal Define R6 (non-XL), the same CPU cooler as you and I have tall RAM. I need to raise the front fan on the cooler a bit, but it all fits. Maybe challenge them on this issue - or ask them to find less tall fast RAM.
The faster RAM isn't really visible in mixing plugin counts (but it is on streaming VI use), but I did find PT to be noticeably more snappy on huge sessions after my RAM upgrade of 3200->4000 DDR4 - keep in mind that low CAS Latency values and the resultant RAM latency (i.e. CL in conjunction with MHz, seek an online calculator) is also important!
IMHO you don't need liquid cooling. I keep my machine on 24/7 for remote connectivity (using the MS Store PowerPlanSwitcher App to make sure I'm on Balanced when not working) and having it air cooled gets me some peace of mind.
You will leave maybe 5% synthetic multicore on the table with the NH-D15 (vs. a really good 360 or 420 liquid cooler), but IMHO it's moot in Pro Tools use. I have never seen PT go above 200W or so on the CPU, and the Noctua can handle that (normal sessions I do hover around 90 to 140W, and they are still large sessions).
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
  #7144
Old 03-31-2024, 11:33 PM
EGS's Avatar
EGS EGS is offline
... IMHO you don't need liquid cooling...
+1. I'm using air cooling on my 11th gen i9, with dual 120mm low db fans. For Pro Tools, I'm clocking all cores at a constant 5.1Ghz.
Desktop build: Pro Tools Studio 2024.6 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626
Laptop: Pro Tools Studio 2024.6 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820
Ancient/Legacy (still works!): Pro Tools 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001
Click for audio/video demo
Click for resume
  #7145
Old 04-15-2024, 12:10 PM
Sugarnutz Sugarnutz is offline
For cooling I'm a firm believer in the Noctua NH-D15 but to fit a 4 space rack chassis I used a Noctua NH-D9L on mt Z390 Designare/i9 9900K rig, no issues and quiet too.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
  #7146
Old 07-09-2024, 02:59 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Unfortunately I've been inactive for a number of reasons for some time now.
I just wonder if any of the first post in this thread gets updated with newest working builds or should I look at the last posts in this thread for updated info on new builds?
  #7147
Old 07-09-2024, 08:37 AM
Its pretty easy to check the first page and then jump to the last(and maybe backtrack a few pages)
  #7148
Old 07-19-2024, 07:26 AM
chrisdee's Avatar
Wich motherboard are you talking about?
  #7149
Old 07-19-2024, 07:27 AM
chrisdee's Avatar
Shure, thanks.
  #7150
Old 08-03-2024, 06:42 AM
WAD WAD is offline
Shure, thanks.
SM57
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
