Re: AutoTune 8 (8.1.8 and 8.0.4) broken in 2022.9
Was there any forward movement on this for anyone? I just upgraded to 2022.10 and boom, autotune 8 crashes every session once its opened either on the track itself or in audio suite. I reluctantly upgraded to AT Pro X after seeing its backwards compatible but its pretty bad honestly. Graphic mode, which I use daily has been pretty severely compromised. You can't even turn off autoscroll in the main GUI nor can you save the settings to keep auto scroll off. That's just one of many small changes that have gone in the wrong direction in my opinion. Hoping someone has a solid workaround (or preferably fix here).
Please help!! |
Yes, Auto-Tune after version 8 is really difficult to work with in graphical mode. I especially find it hard to grab the beginnings and ends of curves - it instead either selects the whole section or just flashes everything red (not helpful at all).
But auto-scroll is still available, they just decided to hide it under the gear icon... |
They just released Autotune Pro X. $175 for upgrade from Pro.
Hello Antares, welcome to the community
#16
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
#17
FYI. Auto tune pro x is problematic in 22.10 for me. Loading multiple instances crashes pro tools. Opening old sessions with multiple instances crashes pro tools. Auto tune pro 9 works fine. Hopefully fixed after the initial release. Sticking with 9 for now.
#18
It won't let me attach videos, but more and more issues just keep popping up.
1. In graphic mode, there is no visual feedback AT ALL in regards to what key/scale you have selected. In AT 8 (and all previous) there was visual feedback as to what's notes are and aren't in your scale. Notes that weren't in the scale were lighter grey and were extremely visually obvious. Major time saver that is now gone. 2. In AudioSuite you can no longer highlight a clip, render that clip and then highlight another clip farther down the timeline. If you do this, it overlaps with the original clip you imported and doesn't follow the timeline. This severely messes with my workflow. I often highlight the first part of a verse, render the graphic mode tuning in audio suite, keep that audio suite Auto Tune open and highlight the next part of the verse and repeat.... now you can't do that. WILD!! 3. MAJOR artifacts when using audiosuite to render graphic mode. Sounds fine while playing back in graphic mode but once you render, boom artifacts galore!! |
#19
Auto-Tune 8.1.8 crashes Pro Tools 2022.10 immediately here, too.
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60 macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4 |
#20
Got this from Antares:
Thank you for reaching out. Auto-Tune 8 is not compatible with the latest Pro Tools update. To continue using this specific Auto-Tune version we suggest downgrading to a previous version of Pro Tools.
Custom Shuttle Lock Speed broken in 2022.5 [PT-290238] | ArchStanton | Pro Tools | 31 | 10-26-2022 10:38 AM |
Looping regions (Audio and MIDI) broken in 2022.6? | XJENSEN | Pro Tools | 3 | 07-12-2022 10:26 AM |
Is the MIDI zoom on the edit window broken in 2022.05 Windows? | snowplaysmusic | Pro Tools | 1 | 06-17-2022 06:44 PM |
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] | Dizzi45Z | Pro Tools | 43 | 05-29-2022 03:59 AM |
autotune update to 7.7.4 still broken!! | Gems Records | Pro Tools 11 | 2 | 04-16-2014 07:50 PM |
