Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
  #61
Old 11-10-2021, 03:16 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Q regarding how to connect TC Clarity M
Originally Posted by Kyle Splittgerber View Post
As I mentioned earlier, please read the 2021.10 What's New guide. See pg 19 "Analog Monitoring with Digital Metering" where it explains how to mirror the MON L-R output to ADAT 1: 1-2.
Does not help as the meter box insists optical SPDIF
Janne
  #62
Old 11-10-2021, 03:44 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Originally Posted by Southsidemusic View Post
” just read this and that ” its it in swedish as i am not from the US so language barriers anyone
We used to have people (techs) just login to our mac and help set it up! Why is this soo hardto get that after 8 years of giving my free time to Avid.? Now i need a few minutes for some tech to look intolur Mac!
If I understand what you are trying to do correctly, the section in the guide I mentioned will allow you to accomplish your goal. Yes, it's in English. But, so is the help here. So, I'm not sure I follow.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
  #63
Old 11-10-2021, 03:46 PM
He has Optical S/PDIF working now. What he needs to do next is mirror MON L-R to ADAT 1:1-2 in Pro Tools. That is what the section in the What's New guide explains how to do.
Kyle Splittgerber
Berkeley, CA
  #64
Old 11-10-2021, 03:54 PM
Southsidemusic's Avatar
It still says N/A under hardware! Not adat or Spdif! So whats wrong then? I cant get those two boxes to say Anything else that N/A whatever I do in the links hou give me.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #65
Old 11-10-2021, 03:57 PM
JFreak's Avatar
How about the newbie advise of hitting default on all i/o setup pages after setting optical to SPDIF? Save your setup first so you can recall it if defaulting does not work.
Janne
  #66
Old 11-10-2021, 04:07 PM
Are you in the session where you got Optical S/PDIF output working (where I think you defaulted all the paths in I/O Setup)? Or, are you in the session with the old Apollo paths?
Kyle Splittgerber
Berkeley, CA
  #67
Old 11-10-2021, 04:08 PM
Sardi Sardi is offline
Looking at your fuzzy pic, it only says N/A for the input. The output shows ADAT or SPDIF. It should be set to SPDIF.
  #68
Old 11-10-2021, 04:39 PM
We only use carbon now! And defaulted all ins and outs and auxes etc as thats what we tell other members when their ins and outs are missing. Thanks though! And we dont have any apollo stuff on this 7.1 mac.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #69
Old 11-10-2021, 04:43 PM
I know it is fuzzy but i said 3 times now we have it set to spdif sorry if that got mixed up. Doesn’t matter which we have, adat or spdif it still says N/A and yes we have it set to spdif otherwise the TC loses the green connection light.
Here is how we have it set! Only spdif and left boxes says N/A whatever we do.
File Type: jpg 855F9E85-3A1B-4ED9-98C2-8915EF74F1E2.jpg (68.0 KB, 0 views)
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #70
Old 11-10-2021, 04:54 PM
Default Q regarding how to connect TC Clarity M
I know it is fuzzy but i said 3 times now we have it set to spdif sorry if that got mixed up. Doesn’t matter which we have adat or spdif it still says N/A and yes we have it set to spdif otherwisethe TC loses the green connection light.
Yes. But it only says N/A on the input in the Carbon hardware setup. The output is all that you need to be concerned with. The meter isn’t sending anything back to the Carbon so you don’t need to be hung up about N/A being visible if it’s only on the input side.
If the output is set to SPDIF, then it will just be a routing issue in your session. So, create a new session with one track and route that out to the Optical output of your Carbon. Are the meters working? My guess would be yes.
Now, with one of your older sessions, I’m assuming you’ve got everything routed to a master fader which you have assigned to your Mon L/R. All you need to do now (as JFreak already mentioned in another post) is route that master to the Optical out in conjunction with your monitoring output. Control click the output on the master fader (this can be done with any track) and you can send to multiple destinations.
TC Clarity X antonis Post - Surround - Video 0 05-02-2018 09:32 AM
TC Clarity M priorytools Avid Pro Mixing General Discussion 1 09-08-2016 01:10 PM
Is anyone using Clarity X? antonis Post - Surround - Video 0 03-08-2016 06:15 AM
Mic clarity bannerj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2004 09:07 AM
Clarity in mixes citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 06-20-2002 10:54 AM
