  #91
Old 01-19-2022, 05:26 AM
stargazer stargazer is offline
Default Re: New Mac - M1 vs Mac Pro 2019
Thank you all!
Now I’ve got some pros and cons to consider.
I will end up on Big Sur sooner or later, so if there’s no other major issues/changes besides the bootable clone-problem/work-around, I think I’ll go for that right away.
Are there any third party developers, hardware drivers etc, that you know of, that hasn’t catched up to macOS 11 yet?
Regarding raid: Darryl mentioned ”lower reliability (due in part to folks making mistakes in RAID setup)”.
I’ve never used any kind of raid before, so what are those reliability problems and mistakes, if I decide to try that?
(I think I’d prefer a raid-0 setup due to simpler organizational structure more than speed.)
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
  #92
Old 01-19-2022, 06:12 AM
JFreak's Avatar
JFreak JFreak is offline
RAID0 means a fault on single drive means fault on entire system. And the more disks you add to the configuration, the more single points of failure you introduce.
In other words you need external backup of it all to be sure you have it. There is no parity, no redundancy, no way of simply replacing faulty disk.
Janne
  #93
Old 01-19-2022, 08:39 AM
Bottom line: As long as I have a reliable backup strategy, it’s worth trying.
I might do two raid-0 with 2x2TB in each on that Sonnet card to make the libraries a bit less fragmented and still less vulnerable than a x4 disk raid.
  #94
Old 07-22-2022, 04:42 PM
SDDP SDDP is offline
Originally Posted by dominicperry View Post
The Pro Vega II is overkill but it does have a lot of TB ports - four.
The only downsides are (1) it takes up 4 slots so if you have a lot of cards (UAD, HDX) you've limited how much space you have left and (2) it will burn more power even at idle than a smaller card.
Most machines came with an Apple 580X MPX which is 1 slot and more than adequate for 3 big screens for audio applications. It has 2 TB ports. Many of these were sold off on ebay for $200-$300.
The Apple 5700X MPX is probably the sweet spot for price vs performance - 4 slots, 4 TB ports, lowish power drain. But $1000 new from Apple.
Selling the Pro Vega II will probably get you $1000-$1200 so you haven't gained much by replacing it with a 5700X.
If the machine has the right CPU for you (12-16 cores is the sweet spot really unless you are doing mental orchestral stuff) and the right amount of RAM and SSD, and is the right price, then the Pro Vega II is neither here nor there. You can swap it for a 580X at some future point and sell off the Pro Vega II if you need the cash.
Was hoping you could give some advice. I have searched far a wide and can't find a concrete answer. I am about to upgrade to the 2019 7,1 16core and was set on the basic Radeon Pro W5500X with 8GB, but wanted to know if upgrading to the Radeon Pro W5700X with 16GB would in any shape or for help on faster offline Quicktime bounces in Protools?
Of course I always freeze (or commit) the haves Plug in tracks to take the load off in rendering/bouncing to a QT same as source in PT. But wanted to know if getting the Radeon Pro W5700X with 16GB would help? And if so how much (well an approximate) %'wise could I expect in bouncing to QT vs. he basic Radeon Pro W5500X with 8GB?
Thanks
-Mac Pro 7,1 16core 3.2GHz 96GB
-OSX 12.7.2
-PTHDN 2023.12 Ultimate
-HD Omni
-BM Intensity Pro
-Waves Mercury+SSL4000 Collection+Abbey Roads
-iZotope RX10 Advanced
-iZotope Post Production Suite 6
-iZotope Music Production Suite 5
-HALO UP/DOWN MIX
-ANYMIX
-Delonghi Perfecta ESAM 5600.S
  #95
Old 07-22-2022, 06:49 PM
Carl Lie Carl Lie is offline
Of course I always freeze (or commit) the haves Plug in tracks to take the load off in rendering/bouncing to a QT same as source in PT. But wanted to know if getting the Radeon Pro W5700X with 16GB would help? And if so how much (well an approximate) %'wise could I expect in bouncing to QT vs. he basic Radeon Pro W5500X with 8GBG
Thanks
This is not the answer you're looking for but curious why now instead of waiting a bit?
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
  #96
Old 07-22-2022, 07:00 PM
dominicperry dominicperry is offline
Thanks
Watch out for the minimum system requirements of the newest Apple MPX cards - the 5700 will run on Catalina whereas the 6800 needs Monterey.
I’ve no idea about the QT question I’m afraid.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
  #97
Old 07-22-2022, 07:42 PM
C
Because of a lot of evaluation and research there is no certainty on how long that little bit wait will be. Especially till it becomes rocksolid with ProTools, video and everything all the third-party plug-ins on the market today. Could be eight months or could be almost 2 1/2 to 3 years from now audio postproduction mixing 5.1 features.
Second it has become extremely tiresome and time-consuming working 12 hour shifts but only getting roughly 8 hours of work done because of constantly waiting on freezing (And then unfreezing for a quick fix just to wait to freeze again) tracks and rendering and waiting some more to make quick times for clients same as source and then converting that into a smaller file from 20 GB to 50 GB something smaller using QuickTime Pro that’s manageable for emailing clients.
For the smaller shows that have extremely quick turnaround times and networks waiting on the final product they after day week after week. It’s not worth it to jump on something much more powerful that I can get increased to productivity.
Others might have different situation but this is mine.
I figured if I’m spending this kind of money mine as well go all out if it would behoove me timewise.
-OSX 12.7.2
-HD Omni
-BM Intensity Pro
-HALO UP/DOWN MIX
-ANYMIX
  #98
Old 07-22-2022, 07:43 PM
Dominic
Not worried about that at all since anyone who buys a brand new 2019 Mac Pro Desktop cheese grater today will take about two weeks till they ship it out/receive it and it’s gonna come with Monterey anyway.
-OSX 12.7.2
-HD Omni
-BM Intensity Pro
-HALO UP/DOWN MIX
-ANYMIX
  #99
Old 07-23-2022, 04:25 AM
Well, clearly it's up to you, but no need to buy a 7.1 new - loads are being sold for knock-down prices at the moment.
Also, even if it ships with Monterey, you can downgrade to Catalina on a 7.1, which has the advantage of allowing you to boot from an external disk easily.
Dominic
  #100
Old 07-23-2022, 12:09 PM
Dominic
I have thought about used, but on the fence. Since I'd be keeping it for at least 7-10 years. Just like my current mac I bought in 2013 (specs in my sig) know that in 5 years or so I can upgrade the internals like I did mine drastically. I NEVER knew or thought I could upgrade the Ghz when I bought mine at 2.4G to a 3.46 and then use 16b sticks and SSD via Pcie years later. So thus the 7,1 being modular (probably the last ever to) makes it a long-term investment. Plus for the first time they have a yearly warranty plan. Was also on the fence about that, but $110 a year till at least the end of this decade for peace of mind goes a long way.
-OSX 12.7.2
-HD Omni
-BM Intensity Pro
-HALO UP/DOWN MIX
-ANYMIX
Drive not seen in 2019.12, seen with 2019.6 Cryos Pro Tools 2019 0 05-30-2020 06:29 AM
HDX Ultimate - 2019.10 7 2019.12 - video export issues anguswoodhead Post - Surround - Video 2 03-09-2020 02:33 AM
Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro rmccam Pro Tools 2019 11 02-28-2020 03:59 AM
Workspace Borked 2019.10 and 2019.12 KMcK Pro Tools 2019 0 01-17-2020 02:09 PM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
