Old 02-26-2008, 09:59 PM
joemail75 joemail75 is offline
Default DAE error 87 and -6 with playback of 24 bit files
Hey all. Ive been running m-powered 7.1 on an xp machine (1.6 gightz, 1.5 g ram, maudio 1814) for over a year with no problem. Now for some reason I go to open up a large session recorded at 48k and 24 bit and it opens...but when i playback it does not play, eventually giving me these two errors. To my knowledge nothing has changed, no settings...its like i was working on it one day and now its wont work. Oddly enough I was able to work on a session in 44.1/16. No apparent issues.
I know the error's point to a fragmented hardrive or not enough space, but ive tried to defrag...it isnt that. Ive also confirmed im using a NTFS hardrive...its just my local C drive...and my disc allocation is correctly set up. Again its worked with this gear up until now so I know it CAN work...i need to find out whats preventing it.
Any ideas as to what could have changed in my machine that this is now happening? I;ve tried all basic general troubleshooting...looking for some expert advice. Thanks for all help.
Old 03-09-2008, 03:34 AM
eddiewes eddiewes is offline
Default Re: DAE error 87 and -6 with playback of 24 bit files
Do you use your C:drive for both Protools and for recording. If so, this could be the problem. Digidesign says that you should use a separate drive for recording and editing your stuff. Maybe this is your problem.
Old 03-25-2008, 02:00 PM
Ryanchristopher Ryanchristopher is offline
I have the same stupid problem and did nothing new!!! Did you find a way to fix it?
Old 03-26-2008, 07:07 AM
dillon99999 dillon99999 is offline
snip - see below
the way to fix it is by installing a separate hard drive for audio (as was mentioned above).
we have seen several posts like this lately, all of them with the same symptoms: Upgraded to 7.4 - it used to work fine on 7.1 - now it's not working.
solution: get a separate hard drive for audio - don't attempt to use the C: drive - and don't try to "partition" it into a separate drive, because that is essentially still using the same "drive".
hard drives are only $30 - a modest investment.
avoid using USB drives - but firewire hard drives are acceptable.
the best choice is either ATA or SATA internal hard drives.
http://www.pricewatch.com/hard_remov...ata_40.0gb.htm @ $27.99
http://www.pricewatch.com/hard_remov...a_ata_20gb.htm @ $19.52
http://www.pricewatch.com/hard_remov.../sata_40gb.htm @ $29.99
http://www.pricewatch.com/hard_removable_drives/
Old 04-13-2008, 03:26 PM
nevertried nevertried is offline
I have the same problem and I have two seperate physical drives. I am able to play almost all of the songs on one drive without the error, but not all. On my main drive I cannot play any of the songs at all without getting the error. I have reinstalled, formatted, defragged. I still have 51 gigs left on my drive and do not have anything running in the background while using Pro Tools. I have been using Pro Tools 7.1 for a few years now without any problems, I have not upgraded or added anything. It was working a week ago and then all of a sudden it won't work anymore. I can't figure it out and Pro Tools Tech isn't helping me at all, I've sent them a few emails and they're not answering my questions. HELP!
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 Karma180 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-05-2011 07:46 PM
Fuzzy Static with ProTools playback and window media files playback 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2011 05:41 PM
PT playback of .m2v files ... soundlife2 Post - Surround - Video 3 07-28-2005 09:04 AM
Files unsuitable for playback KC63 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-02-2004 12:15 PM
.wave files playback Jim Borchardt Pro Tools TDM Systems (Win) 4 03-23-2001 06:07 PM
