Closed Thread
  #601
Old 02-21-2006, 09:55 AM
Fireball71 Fireball71 is offline
Default Re: Problems with PTLE? Post your configuration he
Hey guys,
Can someone tell me what's wrong with this setup for the M-box on PT 6.7???
Thanks in advance.
<<< System Summary >>>
> Mainboard : ASUSTeK Computer INC. A7V600
> Chipset : VIA KT600
> Processor : AMD Athlon XP @ 1833 MHz
> Physical Memory : 1024 MB (2 x 512 DDR-SDRAM PC3200 @ 200 MHz)
> Video Card : Matrox Graphics Inc MGA-G400/450 Chipset
> Hard Disk : HDS728080PLAT20 (82 GB)
> Hard Disk : ST340016A (40 GB)
> Hard Disk : MAXTOR 4K040H2 (40 GB)
> CD-Rom Recorder : PLEXTOR CD-R PX-W1210A CDR, CDR-W (32x ) (12x )
> Network Card : 3COM Corp, Networking Division 3C940 Gigabit Ethernet PCI CODEC
> Operating System : Microsoft Windows XP Professionnal 5.01.2600 Service Pack 1
Music Is Life
  #602
Old 02-21-2006, 02:36 PM
Jonny5_0 Jonny5_0 is offline
Default Re: Problems with PTLE? Post your configuration here..
I have listed my config below. I realize that the processor is not supported, and from reading here that the Ali Magik chipset may also cause problems. But the CD doesn't even load. I am using the MBOX2 on my Powerbook and wanted to load it on the desktop as well, but the CD doesn't even load--and makes my drive disappear. I tried calling tech support today, but at 11am EST 45minutes on wait, i had to go. I just want to know if the disc is faulty, bc i want to load it on a Windows computer in the future. Thanks for your patience with a noob.
< Processor >
Model: AMD Athlon(TM)Processor
Speed: 1.34GHz
Model Number: 1343 (estimated)
Performance Rating: PR1786 (estimated)
Cores per Processor: 1 Unit(s)
Threads per Core: 1 Unit(s)
Internal Data Cache: 64kB Synchronous, Write-Back, 2-way set, 64
byte line size
L2 On-board Cache: 256kB ECC Synchronous, Write-Back, 16-way set,
64 byte line size
< Mainboard >
Bus(es): AGP PCI USB FireWire/1394
MP Support: No
MP APIC: No
System BIOS: Award Software, Inc. ASUS A7A266 ACPI BIOS
Revision 1012
System: System Manufacturer System Name
Mainboard: ASUSTeK Computer INC. A7A266
Total Memory: 512MB
< Chipset 1 >
Model: Acer Labs Incorporated (ALi) ALI M1647
ALiMAGiK 1 AGP System Controller
Front Side Bus Speed: 2x 134MHz (268MHz data rate)
< Video System >
Desktop Monitors/Panels: 2
Monitor/Panel: Default Monitor
Monitor/Panel: Plug and Play Monitor
Adapter: RADEON 7200 (Microsoft Corporation)
Adapter: NVIDIA GeForce4 MX 4000 (Microsoft
Corporation)
< Physical Storage Devices >
Removable Drive: Floppy disk drive
Hard Disk: WDC WD400BB-00AUA1 (37GB)
Hard Disk: DMI 00GVC0 IEEE 1394 SBP2
Device
CD-ROM/DVD: SONY DVD RW DRU-710A (CD 48X Rd, 48X Wr) (DVD
6X Rd, 6X Wr)
< Logical Storage Devices >
1.44MB 3.5" (A:): N/A
Hard Disk (C:): 24GB (14GB, 56% Free Space) (NTFS)
Hard Disk (D:): 13GB (2.2GB, 17% Free Space) (NTFS)
CD-ROM/DVD (F:): N/A
External (G:): 233GB (194GB, 83% Free Space) (FAT32)
< Peripherals >
Serial/Parallel Port(s): 3 COM / 1 LPT
USB Controller/Hub: ALi PCI to USB Open Host Controller
USB Controller/Hub: USB Root Hub
FireWire/1394 Controller/Hub: OHCI Compliant IEEE 1394 Host Controller
Keyboard: Standard 101/102-Key or Microsoft Natural PS/
2 Keyboard
Mouse: PS/2 Compatible Mouse
Mouse: HID-compliant mouse
Human Interface: USB Human Interface Device
< MultiMedia Device(s) >
Device: Game Port for Creative
Device: Creative AudioPCI (ES1371,ES1373) (WDM)
< Communication Device(s) >
Device: Standard Modem
< Printers and Faxes >
Model: Brother HL-1440 series (Copy 1)
< Power Management >
AC Line Status: On-Line
< Operating System(s) >
Windows System: Microsoft Windows XP/2002 Professional (Win32
x86) 5.01.2600 (Service Pack 2)
< Network Services >
Adapter: Linksys NC100 Fast Ethernet Adapter
  #603
Old 02-22-2006, 10:34 AM
eddiewes eddiewes is offline
I have an Intel PBL915 mainboard and wondered if it's compatible with PTLE 7 and Win XP pro s-pack 2
regards
Eddie
  #604
Old 02-22-2006, 11:24 AM
spkguitar's Avatar
regards
Eddie
It's not the software that you need to be concerned about, but the hardware. Check the Compatibility page for the hardware that you are considering. (I can tell you right away, if it's mbox or mbox 2, the answer is no).
  #605
Old 02-25-2006, 04:53 AM
iaings iaings is offline
Hi there,
Below is my system information. I have an Mbox2 with PTLE, version 6.8.1. From all the information I was able to read, it seemed to me before purchasing this that my computer would be good enough to run it. However currently my recording is limited to one track for 5 seconds, before I either get the "the operating system held off interrupts for too long" message, or the "audio processing conflicts with other cpu tasks" message, depending on the H/W buffer size.
I completed all the requested system settings changes in the getting started guide before installation, and I have since tried everything in the "General Troubleshooting - Pro Tools 6 & 7 Win XP" thread. Nothing there made any difference except the "Adjust Processor Scheduling Performance" sugestion, which caused mindows not to load at all.
What am I missing? Any suggestions would be most appreciated.
< Processor >
Model: Intel(R) Pentium(R) 4 CPU 2.80GHz
Speed: 2.79GHz
Performance Rating: PR3715 (estimated)
Threads per Core: 2 Unit(s)
Internal Data Cache: 16kB Synchronous, Write-Thru, 8-way set, 64
byte line size
L2 On-board Cache: 1MB ECC Synchronous, ATC, 8-way set, 64 byte
line size, 2 lines per sector
< Mainboard >
Bus(es): X-Bus PCI PCIe IMB USB FireWire/1394 i2c/
SMBus
MP Support: 1 Processor(s)
MP APIC: Yes
System BIOS: Dell Inc. A03
System: Dell Inc. Dell DV051
Mainboard: Dell Inc. 0JC474
Total Memory: 1015MB DDR2-SDRAM
< Chipset 1 >
Model: Dell Computer Corp 82915G/GV/GL/P/PL/GL
Grantsdale Host Bridge/DRAM Controller
Front Side Bus Speed: 4x 200MHz (800MHz data rate)
Total Memory: 1GB DDR2-SDRAM
Memory Bus Speed: 4x 133MHz (532MHz data rate)
< Video System >
Adapter: Intel(R) 82915G/GV/910GL Express Chipset
Family
Hard Disk: Maxtor 6L160M0 (149GB)
Hard Disk: WDC WD1200JB-00EVA0 (112GB)
CD-ROM/DVD: PHILIPS DVD+-RW DVD8701 (CD 48X Rd, 48X Wr)
(DVD 6X Rd, 6X Wr)
Hard Disk (C:): 99GB (69GB, 70% Free Space) (NTFS)
Music (M:): 50GB (26GB, 52% Free Space) (NTFS)
Pro tools (P:): 112GB (111GB, 100% Free Space) (NTFS)
< Peripherals >
USB Controller/Hub: Intel(R) 82801FB/FBM USB Universal Host
Controller - 2658
Controller - 2659
Controller - 265A
Controller - 265B
USB Controller/Hub: Intel(R) 82801FB/FBM USB2 Enhanced Host
Controller - 265C
Keyboard: HID Keyboard Device
Model: Dell Photo Printer 720
Windows System: Microsoft Windows XP/2002 Home (Win32 x86)
Network Drivers Enabled: No
  #606
Old 02-25-2006, 05:12 AM
spkguitar's Avatar
iaings,
What am I missing?
The Compatibility page which is referenced on page 3 of the getting started guide, and is the first suggestion on the Gen. Troubleshooting thread. The very first thing on the Compatibility page is:
<font color="#666666"> Chipset Compatibility Alert
* Digidesign's Mbox 2 is not compatible with desktop computers with the following chipsets:
o Intel 915G
o Intel 915P
o Intel 925X
* 915GL, 915GV, 915PL, and 925XE are compatible, see Chipset Requirements with Intel P4 processors
* For more about this issue, see the following information provided by Intel:
o Intel 9xx Chipsets & Mbox 2 Compatibility
Your computer unfortunately falls into that category. Some people have had success getting around this problem by plugging into a powered USB hub, but there are no guarantees with that method.
  #607
Old 02-25-2006, 05:27 AM
hang on... doesn't that say that 915GV chipset is compatible?
according to my paperwork from dell, that is what i have. Are they lying to me??
thanks for the quick response!
  #608
Old 02-25-2006, 05:42 AM
spkguitar's Avatar
I honestly don't know.
The only other issue that stands out could be the hard drives. Do you have Pro Tools installed to the system drive? Have you double checked that all drives are running in DMA mode? Are they connected to the same IDE channel, or is one of them sharing with the DVD?
  #609
Old 02-25-2006, 06:03 AM
Both drives are definately running in DMA mode. Please excuse my limited technical understanding, but by, same IDE channel, I presume you mean are they are on the same cable inside the computer. Which they are not. The non-system drive shares with the dvd drive.
PT is installed on the system drive, but I record (or try to) to the other drive. None of the literature i have read implies this would be a problem, but I could be misinterpereting.
  #610
Old 02-25-2006, 06:17 AM
spkguitar's Avatar
This could be causing a problem. Try putting them on the same IDE cable.
Closed Thread
Problems with PTLE? Post your configuration here...... still_life_ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-30-2007 12:27 AM
Problems with PTLE? Post your configuration here.. DJ John 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-28-2007 10:06 AM
Problems with PTLE? Post your configuration he krsongs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-28-2007 09:59 AM
Problems with PTLE? Post your configuration here.. p3tch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-28-2007 09:46 AM
Problems with PTLE? Post your configuration here.. Gaba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-23-2007 08:01 AM
