Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 09-12-2024, 04:58 PM
Ooptron Ooptron is offline
Default MTRX Studio Mic Input via DVS
Hey guys,
I have the MTRX Studio configured for Atmos via DVS at the studio. I run Nuendo, so no Digilink or Protools configs. I used the Dante Controller app for setting up the routing between DVS and DADman.
Due to an unforeseen technical failure, I need to use the Mic input on the MTRX Studio to record voiceovers next week. Is it possible to route the Mic inputs to the DAW while using DVS?
In DADman's matrix, I tried mapping the AD to the Dante Main matrix column, but couldn't get any Mic signal to show up in the DA monitor section no matter where I routed it. I only managed to get the Mic input to the Control Room section via the Monitor profile. Couldn't get any signal into the DAW for recording.
Is this a routing error, or is this not possible using DVS? What could I be missing? Do I need to map something in the Dante Controller app? Any help is appreciated. Thanks!
Old 09-12-2024, 05:39 PM
Default Re: MTRX Studio Mic Input via DVS
Only issue I can think you should run into would be DVS channel count issues at high sample rates, ... and you don't say what the sample rate is (and I'd assume you get those chopped off the upper channels anyhow).
Does the Inst/Mic AD should show up in the routing matrix, and always showing signals in DADman on those two inputs? Everything look correct? If stuff there is not making sense maybe post screenshots (on a photo sharing site and post the link here to avoid it being uselessly downsampled by DUC).
Personally I would ditch DVS in a hearbeat and get the lovely Thunderbolt option card.
Old 09-12-2024, 07:22 PM
I'm running at 48kHz, so not a very high sample rate.
Yes, both Mic/Inst show up in the routing matrix with active signal. I'll grab screenshots when I'm in the studio next and post them here. It could be just a routing issue.
Yep, would love to upgrade to the TB option card, although I read it takes ages for it to ship. However, I work a lot with recording and use UA Apollos for it and end up utilizing the MTRX Studio only for surround/Atmos mixes. I do prefer the sound of the MTRX Studio, especially with my room calibration.
Old 09-13-2024, 04:27 AM
creativecontrol's Avatar
Certainly agree with Darryl that you will have much better workflow and latency with the TB3 option once you get it.
Regarding DVS, this should also work as IO in a pinch.
A/D = Source/Input -> Dante = Destination/Output in the DADman patchbay.
Then, in Dante Controller, Source = MTRX ST (top), Destination = DVS (bottom left, your workstation name)
That will complete the conduit from a mic, line, or DI input to patch to the IP Audio network. To Monitor, it sounds like you have that sorted - with a Source in your Monitor Profile coming from Dante. This would have have been patched in a reverse manner in Dante Controller:
Source = DVS (your workstation, top) to Destination = MTRX ST.
Happy to help if you want to illuminate further with some images.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-13-2024, 04:05 PM
Thanks, Jeff!
I think it's the Dante Controller bit which always gets me. I find the UI too damn confusing, haha.
I'll try this out later in the studio today and grab some screenshots if I'm unsuccessful.
Old 09-14-2024, 07:34 PM
best,
Jeff
Thanks a ton Jeff! It was the Dante Controller patching in which was the problem. Working great now.
Old 09-16-2024, 05:08 AM
Glad to hear it!
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
MTRX Studio: Audio Input Latency SpeakingStrings Pro Tools | MTRX & MTRX Studio 5 10-28-2023 08:00 AM
MTRX MTRX Studio Forum Section? off the wall Pro Tools | MTRX & MTRX Studio 2 05-08-2022 03:20 PM
MTRX Studio - Output fine, no input now Matt Stephanson Pro Tools | MTRX & MTRX Studio 15 08-28-2021 07:59 AM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
Mtrx Studio DB25 Avid Cable for analog input cerisaie Pro Tools | MTRX & MTRX Studio 11 11-16-2020 02:21 PM
