Old 09-12-2024, 09:04 AM
riantide riantide is offline
Default S/PDIF Device: no audio when recording, only on playback
This is the weirdest thing I've seen in 20+ years of using Pro Tools but here goes:
I have a BURL Bomber ADC connected via S/PDIF to an Apogee Ensemble and for some reason I get no audio when input monitoring or recording (meters for the Burl, Apogee, and Pro Tools all show a healthy signal), but anything I record plays back just fine once the track isn't armed anymore. This happens whether I'm monitoring off the analog outputs of the Apogee or the S/PDIF output to my Grace M905.
Everything was just working yesterday, only thing I've done since is backdate Sound ID Reference to a previous version to address an issue I was having, as per support's recommendation.
All hardware has been power-cycled and the computer has been restarted multiple times.
Update: it's not just the Burl, all inputs on the Apogee are exhibiting this problem. I already know it's gonna be something stupid I'm overlooking but I just can't find it. Does this ring any bells for any of you kind internet strangers?
System:
2018 Mac Mini running 10.15.7
Pro Tools 2023.9.0
Apogee Control 6.0.26
Old 09-12-2024, 10:01 AM
tope d's Avatar
tope d tope d is offline
Default Re: S/PDIF Device: no audio when recording, only on playback
System:
Pro Tools 2023.9.0
try creating a session and import saved session's data on the new one and see if the same issue occurs. Let me check for similar cases
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 09-12-2024, 12:43 PM
This is about as dumb as I was suspecting it would be, but I need to post this in case anyone finds themselves in the same position:
Low Latency Monitoring was turned on. I never use that feature, so I didn't think to check.
Back to your regularly scheduled programming...
Audio Playback Device issues with Intro (Windows) MisheGossnik Windows 9 07-04-2023 11:12 AM
CORRECTION: Adat Device doesnt playback audio during Recording or Playback DarylBham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 07-21-2010 11:16 PM
audio device underflow(-6085) during Playback M577 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-01-2008 07:16 AM
audio device underflow(-6085) during Playback M577 Pro Tools TDM Systems (Mac) 4 05-26-2008 04:38 AM
audio playback device: major issue coolhunter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-23-2004 02:24 PM
