Error -22003
Since updating to 2024.6 my protools has been somewhat sluggish. I've gotten this -22003 error and I can't seem to figure out what is causing the sluggishness. I'm on the latest OS 14.5. Also, when I try to switch the meter output at the top of the edit window ProTools crashes. I opened up an older session and it worked fine with no issues so it's hard to figure out why this is happening.
Re: Error -22003
So I did get the output meter path working but only when I switched from the Internal renderer to the external renderer so I'm not sure why that is happening.
Re: Error -22003
Hi Goombot,
I created case 04826523 and submitted it to tech support team for further investigation.
Regards, Charles ________________ To create an Avid Support Case, you may go to https://avidtech.my.site.com/avidsup...t-support-page |
Re: Error -22003
So it seems like it's down to the IO. Everything in my IO works fine. It's a very large and complex IO but it all works when I delete most of my beds. I can add about half of them when I try to add one more and I select the output meter PT crashes. So it's something with the IO.
Re: Error -22003
So I moved back to the previous version of ProTools and I'm still having the same issue. I'm wondering now if it could be something with my Sync X firmware update or HDX driver updates. Really frustrating.
Re: Error -22003
Hi Goombot,
I check your case 04826523 and I saw our technician replied. Can you check if the troubleshooting steps will work?
Re: Error -22003
I'm looking at the case now. I will respond there. thank you.
Re: Error -22003
I've supplied a ton of information for this case with no response. Can someone please get back to me about this? thank you.
Re: Error -22003
I made a follow up as well on your case. We apologize about the inconvenience.
Re: Error -22003
Am I missing something because I don't see any follow up in the case.
Transfer of Ownership Fail - Error: Error occurred while loading a Visualforce page | Chevron | Licensing & Accounts | 10 | 12-19-2019 12:35 PM |
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error | EricMulhern | macOS | 1 | 11-20-2011 05:39 PM |
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 | Karma180 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2011 07:46 PM |
Error type 10,address error ,illegal error, buss error ,illegal instruction | KasticK | Pro Tools TDM Systems (Mac) | 3 | 05-14-2003 11:21 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
