#31
just chiming in to say this happened to me last week on an ad for a huge brand with on screen talent singing tons of alts, and only at the very last moment luckily found a section where the tuning disappeared and was able to fix.. It said all tracks were corrupted but only a tiny section of one track was pitchy again, and its hard to spot if the performances aren't awful to begin with. stressed me out
ARA is incredible in theory so really hope the bugs get worked out! |
#32
![]() Quote:
Why do both?
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
#33
Absolutely nothing. Committing is redundant to Rendering.
#34
I decided to give ARA Melodyne a shot tonight and documented my findings in another thread. I learned A LOT! I learned what I was doing wrong and fixed my errors. It's not intuitive, but applying some good old fashion engineering helped me figure stuff out.
Rendering Melodyne wants the full track. So if you have 5 measures of recorded track data before you start playing, then you decide to shorten that track to the first transient; it doesn't like that. Stretch the track back to the beginning where you started recording, then render. You can fix the "dead air" later. Rendering Melodyne also doesn't like tracks that have multiple edits with cross-fades. Make sure tracks are uptight and cross fades are perfect. Then consolidate your track and then render. Again, I did a save as version before I started consolidating tracks. Do lots of "Save-As" giving yourself a good fall-back version just in case things go wrong. I had 4 hours of trial and error tonight, so I'm happy I had fall back, and each time I figured something new out.
5K Retina 27" (2020) iMac OS 15.3 Sequoia 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.10.2 EuCon 4.8.6.41 / 2024.10.0.19 UA Luna UAD 11.5.2 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
#35
![]() Quote:
Because of all the problems I see reported on the DUC, I never use ARA Melodyne. When I need to use Melodyne (not often) I use the old fashioned way, and that's been totally reliable for me - no need to commit, change edits etc. The last thing I want to do is turn PT into the worst aspects of Cubase - no amount of convenience saved with ARA is worth this list of caveats and workarounds. The thread title might seem hyperbolic, but imo it's justified. Until it works as reliably as the rest of PT (no sniggering at the back - it really is more solid than Cubase), avoid ARA. In the meantime, it's worth passing on this list to support in the hope that they start to track down the plethora of bugs.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
#36
![]() Quote:
1. Do ARA edits disappear in the session in fact after this error? 2. Have you tried to use the backup session to recover? Does it help to recover ARA edits? 3. Was any Import Session Data made into the current session multiple times or from the other session with ARA edits (with the common source files)? |
#37
i've been complaining about this since it first came out. serious issues with melodyne in ara, and it's frustrating when avid keeps saying they can't reproduce it. Clearly enough people are having this problem that it's a legitimate issue. Not only is the loss of ara files a huge problem, but the save time when you're using auto save is insanely slow and totally interrupts the work flow.
#38
![]() Quote:
I've only seen this error once in a few months of using the new workflow, but once is enough! Working with an important client present, spend half a day editing vocals with ARA, put the session away and work on some other sessions, no crashes, all is fine, then come back to it at the end of the day for a few additional tweaks and it throws the "Some melodyne track data can't be found". To client: "ummm, sorry - I guess we're gonna have to go through this entire track again to be certain we're not missing something..." UGH! That happens more than once and you've lost a client. As support so often says to us, we need more information to help figure this out - help us help you help us! thx! rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Sonoma, PT Ultimate 2024.10.1. HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 Last edited by Rich Breen; 06-26-2023 at 10:39 AM. |
#39
![]() Quote:
Good stuff of which I am passing along and adding to what has already been posted..... Thanks Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
#40
![]() Quote:
But I get what you are saying that committing as soon as you can is a good thing. Unfortunately, with the current version of ARA, this requires committing much earlier than I would hope for. Like others, I will likely move back to using the plugin version of Melodyne. Regarding going back to Auto-save versions, I tried that and even after going back to auto-save versions older than 45 minutes, it still wouldn't open. It was like the version I had been working on would save, but realistically would never open because something with ARA has become corrupted. It took me over 2.5 hours of importing session data a few tracks at a time and then rendering whatever Melodyne I could before I could finally restore my session completely. After rendering all Melodyne clips, I went into the clips bin and erased all clips that had any Melodyne on them until my project was ARA free.
Pro Tools HDX 2025.6 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 15.5 Noisebox Studios -Utah Recording Studio |
Sends stop working if I press stop/play too fast.. 12.4 | thierryhenry | Pro Tools 12 | 0 | 12-21-2016 03:26 PM |
Scroll behavior when you stop--stay where you stop, or go back to playback point? | bashville | Pro Tools 10 | 15 | 01-26-2013 05:56 AM |
is there a way to stop this | protooleriate | Pro Tools TDM Systems (Mac) | 7 | 10-04-2004 07:56 AM |
Petition to Stop Petitions to Stop Petitions | Nippamuk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-21-2003 03:40 PM |
Bass Tones. Stop. Require Assitance. Stop | dmcgilli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-14-2003 05:21 PM |
