Old 03-05-2024, 04:31 AM
Gregor B. Gregor B. is offline
Default Waveform Zoom Bug
Dear All,
For a very long time I thought that - after some update - S6 had lost the ability to mirror the waveform zoom from the PT edit window. Now, I just realized it actually still works for some tracks that are higher in the session, but only until a certain point. After that point only the waveforms in the edit window will move according to the zoom commands, but not on the S6!
In my session this point is between track 305/306.
If I count only audio tracks, it's between 214/215. In other words, waveforms on S6 for any track of a higher track number than that will not react to the zoom command.
Btw. this happens regardless of whether I use the keyboard shortcuts "cmd+option+[]" or S6 softkeys.
Does anyone experience this?
Best
Gregor
Old 03-05-2024, 05:42 AM
tope d's Avatar
tope d tope d is online now
Default Re: Waveform Zoom Bug
Originally Posted by Gregor B. View Post
Dear All,
Best
Gregor
Hi Gregor!
Couple of questions..
1. What version of WSControl is installed?
2. What version of S6 Software is installed?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-05-2024, 04:00 PM
basehead617 basehead617 is offline
This bug has been shared by several people and I think is in progress, right Eddie?
Old 03-06-2024, 08:13 AM
I updated this morning just to make sure, both is on 2023.11.0.121
The problem persists.
Old 03-06-2024, 09:11 AM
EddieJones's Avatar
This is a known issue and we are looking into it.
Old 09-12-2024, 02:20 AM
...sorry if I have to throw in a lame BUMP, but this is my number one workflow killer on a daily basis working on feature films. I'm someone who does almost everything from the console and don't look at the ProTools editing window at all, which means more often than not I'm looking at "thick sausage" waveforms that don't reveal what's going on and I can't do anything about it.
I think some flag must be set somewhere that tells S6 to save resources and only adjust waveform until a certain track or folder number. I know inactive folders play a role, but erasing them won't fix the problem.
Any updates or possible workarounds would be much appreciated!
Best
Gregor
Old 09-12-2024, 08:49 AM
EddieJones's Avatar
This should have been fixed in PT24.6, are you still seeing it?
Old 09-12-2024, 09:26 AM
creativecontrol's Avatar
These are definitely fixed on upcoming PT + S6 versions as I'm seeing correct behavior here. I can revert if needed if your mileage varies.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Waveform weirdness with zoom in/out TrentWilliams Pro Tools 12 18 09-16-2017 02:05 PM
different waveform zoom setting webstereo Pro Tools TDM Systems (Mac) 6 05-07-2008 06:56 AM
Waveform vertical zoom thing... Kuba Pietrzak Post - Surround - Video 6 01-17-2008 12:31 PM
waveform keeps disappearing when I zoom in.PT7.3.1 jselgin Pro Tools TDM Systems (Mac) 0 01-19-2007 02:33 PM
Individual Track Waveform Zoom Coll Pro Tools TDM Systems (Mac) 2 01-17-2006 05:10 AM
