Old 02-27-2012, 01:15 AM
ozzlvlosis ozzlvlosis is offline
Default MBOX2PRO + Onboard Audio
I'm building a new PC right now but with my current PC, i have to go into device manager and disable/enable the Mbox driver if I want to go into Pro Tools.(otherwise i get no sound).
Supposedly this is because the mbox can only handle one application at a time however, when I'm already in Pro Tools I can use other applications like winamp or google chrome to listen to audio simultaneously. As annoying as this is I've gotten used to it.
What I'm thinking about doing with my new build is just getting a second pair of speakers for the onboard soundcard and keeping this pair of speakers just for the mbox2 output. The idea being not having to disable or enable any drivers at all.
Has anyone had a setup similar to this that could shed some light? Will it cause any conflicts? It's basically two soundcards with their own set of speakers.
Old 02-27-2012, 08:04 AM
mano111 mano111 is offline
Default Re: MBOX2PRO + Onboard Audio
Thats the way most PT users I know have it setup.
Sound from PT should go to dedicated Monitors for mixing, yet the sound from the PC is often mastered loud and of various quality deserving its own set of speakers.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
MBox Micro vs onboard audio. sunburst79 General Discussion 3 12-06-2010 02:02 PM
I have to enable onboard audio for 8.0.4 to start !? neuromillion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-08-2010 05:16 AM
Windows laptop onboard audio? mike_mccue Pro Tools 9 5 11-06-2010 11:18 AM
Disable Onboard Audio? zombie69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-04-2006 05:08 PM
M-Powered work with onboard audio output ? wangell Pro Tools M-Powered (Mac) 0 01-11-2006 05:09 PM
