Reason/REWIRE not working in PT 6.1.2
Reason is no longer in my plug-ins list. I reinstalled Reason, problem not fixed. I need to know which Reason file must be in which correct Digidesign folder.
I hope somone can help me. thank you |
Re: Reason/REWIRE not working in PT 6.1.2
i'm having the same problem, but on my MacBook Pro running the new intel versions of both PT LE 7 and Reason 3.0.4. Can somebody please help?
I had some of the same problems in 6.1---what you have to do is make sure Reason is launched first, before your PT LE session. If you forget and have a PT session open first, and try to insert Reason, it'll toss the plug out of the folder for some 'reason' (heh.) If that happens, just make sure that there is an alias at least of the Reason start icon, in your Plug Ins folder under: Apps-Digidesign-Plug Ins. Doing these things seemed to work for me.
i just tried that (i have PT 7 for the MacBook Pro but am having the same problem).
i'll get back to you with results. |
Primary: 2019 Macbook Pro 15inch 2.6ghz Intel Core i7 OSX 10.14.5 Mojave 16GB RAM Pro Tools 2019.5 Secondary: 2015 iMac i7 27" 1TB SSD. 32GB RAM. OSX 10.11.6 El Cap Pro Tools 2018.3 Rosetta 200 I/O via X-Symhony into TB2 Akitio Chassis Session and Sample drives in TB2 Akitio Thunder2 Chassis Server: 2008 Mac Pro 3,1 2x2.8 Quad-Core Intel Xeon Target Disk - OSX 10.8.5 Mountain Lion 22GB 800Mhz DDR2 RAM |
Rewire Reason 6.51 to PT9 not working? | lwilliam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-30-2012 11:52 PM |
Reason 4 + 002 not working in Rewire mode. | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 08-23-2010 12:25 PM |
Pro Tools LE and Reason 4 w/ Rewire not working. | cringe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-12-2008 01:28 PM |
Cannot get MIDI working with Reason Rewire... | Chewits | MIDI | 7 | 08-17-2005 10:30 PM |
Reason working in standalone, but not with ReWire. | pedrohead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-19-2003 05:56 AM |
