Old 11-27-2015, 03:35 PM
Vercingetorix Vercingetorix is offline
Default No Eleven Rack window in PT11?
Hello guys,
Please don't crucify me for not knowing this it's been a long time since I did anything in PT regardless of the version.
Now I have been dying to try and BIAS Amp Desktop with PT and finally had a chance yesterday I ran into a problem with the playback engine not working. Just a moment ago I got it up and running, set up BIAS amp on the 11Rack track using an insert and wanted to turn off the amp and effects sims to hear what BIAS was producing but the 11R window was greyed out.
So what should I do now? I used to use that window for re-amping and recording direct can the Eleven Rack editor be used instead for this?
Thankyou and Regards.
You're validating my inherent mistrust of strangers.
Schecter Hellraiser 7 Diamond - Ibanez RG7620
Eleven Rack w/ ERXP
Old 11-27-2015, 05:38 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: No Eleven Rack window in PT11?
Gotta use the Standalone Editor.
http://connect.avid.com/eleven-rack-editor.html
However, you should not need to disable the Amp/effects of the Eleven Rack if you are using Pro Tools. Just use a MONO AUDIO TRACK, insert BIAS, set the Input of the track to GUITAR. That is the dry guitar sound. You should not be hearing the Eleven Rack amps.
If you are hearing the Eleven Rack amps, more than likely you have the problem where the Eleven Rack driver does not turn off monitoring. Check this video for a solution. Be sure to use a STEREO Audio Track when you cycle LLM
Brian
Windows 11 Pro
Pro Tools 2021
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Instagram
New PC for PT11/Eleven Rack Mr. Jack Getting Started 19 04-02-2016 03:22 AM
Eleven Rack GUI in PT11 SeattleHD Eleven Rack 58 01-27-2014 11:05 PM
Need Help !! Eleven Rack/PT11 Mark Lemieux Pro Tools 11 6 07-08-2013 12:47 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
