export midi
hey folks...
baffled. i'm exporting a PT session as an OMF, and the midi doesn't xfer. fine. i export the midi tracks and export a midi file and the only thing that happens when i re-import that midi data into a new session is i get the memory location markers. what am i doing wrong? the tracks are highlighted, as is the whole time-line. PT version 7.4 HD/3 Mac OS 10.4.11 2 x 2.66 dual core xeon 5 GB memory thanks, marty. |
Re: export midi
OMF only does audio not midi You'll need to do a midi file as well as OMF. the midifile does the location markers as well as the midi and the tempo map!!!! Chris
Re: export midi
thanks for the reply...yeah, i have done a separate midi file yet no actual midi tracks come along in the export. very odd.
Re: export midi
ok...pilot error of course. been so long since i've exported midi. turns out
it was either because the midi track was muted, or the track was in notes mode rather than regions mode...but more than likely because i had the track muted. hope this helps someone as forgetful as i, marty. |
Re: export midi
Hey Marty -
Yeah, must UNMUTE all tracks you want to transfer. As you figured out, it's a 2 step process - OMF & MIDI for tempo map, etc. Bill |
Export MIDI Without General MIDI assignments | grhufnagl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-24-2009 09:12 AM |
Export MIDI produces corrupted data. Unable to export MIDI ! | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-01-2007 07:18 PM |
Midi export | Toontrack | Pro Tools TDM Systems (Mac) | 2 | 08-07-2006 10:13 PM |
protools midi export to garageband midi? | speky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-23-2006 10:39 AM |
Export MIDI ?? | Virtual | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-30-2002 08:03 PM |
