Old 03-02-2004, 04:25 AM
sgerst sgerst is offline
Default Reason loop audio drop out??
Using Reason 2.5 via Rewire on PTLE 6.2.2 with dual G5 2 Ghz-
OS 10.3.2-
now having audio drop outs at loop point in 8 bar loop with only 8 Reason tracks-
I have searched the forum but can't find a report of this problem-
perhaps it is related to 10.2.2 with 6.2.2, but I wanted to find out if:
1) others have had this problem- any suggestions and
2) is Digi aware of it for 6.2.3 update.
Any help would be appreciated
Scott
Homme Remixing
NYC
212-421-1860
Old 03-02-2004, 08:15 AM
martian martian is offline
Default Re: Reason loop audio drop out??
are you getting error mesages?
I was and the cpu interupts should say get more RAM. I was on standard 512 and that was the beef until I stuck another gig of ram in there...
I was also getting drop-outs on the rewire stuff too, it seemed to co-incide with moveing knobs on my oxygen 8. again more ram did trick.
now if someone could just tell me why I can't get the takes list popup to popup I will be happy
hopefully karma will prevail
Old 03-13-2004, 02:13 AM
No error messages-
1 Gig RAM-
it's like a hiccup when looping only at the loop point-
only occurs when running PT / Reason via Rewire-
anyone with any ideas?
I'm checking out 6.2.3 later this weekend-
Scott
Homme Remixing
NYC
212-421-1860
Old 03-13-2004, 05:07 PM
clockface clockface is offline
Pro Tools and Rewire aren't really meant to be used with the loop mode in Reason turned on. Copy and paste the passage you are trying to loop and let it play linearly. I think your drop out is happening because Reason is supposed to be slaved to Pro Tools (hence the reason you control tempo from the PT transport, not Reason's), and when reason loops back to the start, it takes a moment for PT to reset back to that point and regain control.
Of course I may be completely wrong, but I don't think so this time.
Old 03-13-2004, 05:22 PM
lamp lamp is offline
Not sure if this is your problem but, You have to set your loop points in the edit screen midi track in PT. Not in reason.Just select and drag.
Old 03-13-2004, 06:27 PM
Thresholdproductions Thresholdproductions is offline
This happens to me as well and it happened with logic as well. logic is worse.
Elastic Audio > drag drop loop > session not mapping to loop tempo 440Hz macOS 3 07-04-2011 07:35 PM
Record a reason loop into pro tools NicBillionaire Tips & Tricks 8 05-30-2007 01:34 PM
How to get a Reason Rex Loop over to Pro Tools??? floridajohn Tips & Tricks 1 12-28-2005 12:30 PM
Reason has a drop when cycling in rewire with PT pwolfy Pro Tools TDM Systems (Mac) 0 08-10-2004 06:09 AM
Reason Rewire Loop Glitch mpc_dv8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-15-2003 10:47 AM
