Elastic audio PT 8 problem
Hello,
Im on XP running PT 8 and 003 rack.I having a problem with elastic audio actually working and wondering if anyone can give me insite into some areas I might not have tried. first I created a new section at 130 bpm. I have brough in 2 different drum loops that PT says source tempo is 134. These 2 separate tracks will not sync at all. Elastic audio is enable per track and set to rhythmic on each track. I have even tried conform to tempo on each track.no luck. Is there something im missing? Any input would be appreciated Thanks |
Re: Elastic audio PT 8 problem
sounds like the loops them selves may not be cut properly.
forgive me for assuming your skill level but have you made sure they're topped and tailed properly? |
yes I have. Trimmed in PT and also check them in Wavelab individually they loop seamlessly
Thanks |
Have you used the time-trim tool in grid mode to set their respective legnth?
conform to tempo wont allways work for me either...
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
Elastic Audio Problem | LonestarBeatz | Pro Tools 11 | 0 | 07-18-2013 07:56 PM |
elastic audio problem | edwallace | Pro Tools 10 | 1 | 03-01-2013 09:21 AM |
Yet ANOTHER problem, now with elastic audio, I can't be the only one! | farmfresh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-17-2009 07:25 PM |
Problem in Elastic Audio (LE 7.4) | brentrains | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-06-2009 09:24 AM |
elastic audio problem | harryk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-21-2008 02:20 PM |
