Old 04-18-2013, 08:01 PM
garnoil garnoil is offline
Default How to export a plugin list
I am sending a mix to another studio and they asked me to send them a list of my plugins. Is there an easy way to do this (like an export plugin list command) or do I have to go to the plugin folder and copy and paste to a word document?
g
Old 04-18-2013, 08:26 PM
Default Re: How to export a plugin list
g
There used to be a generate plugin list function off the help menu in PT. I’m not sure its still in 10.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
Old 04-18-2013, 11:01 PM
cjguitar cjguitar is offline
Select menu File>Export>Session Info as Text… and click check box "Include Plug-In List".
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
Old 04-19-2013, 06:09 AM
Old 04-19-2013, 06:45 AM
quadraphonics quadraphonics is offline
There is a plug in/program called Plug Tools that can generate a CSV file with version info for every plug in you have on your system.
Randall
g
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 04-25-2013, 01:24 AM
tamasdragon tamasdragon is offline
And if you're not only want to export it, but would like to check if you're up-to-date, check out pluginupdate. It's a great utility.
my blog:Tamas Dragon
Old 11-24-2022, 03:37 AM
kosmokrator kosmokrator is offline
Hi there,
any solution to this in 2022?
The tools mentioned no longer seem to be around.
I can export a list of the plugin direcotry, that doesn't help much though, since f.e. all Waves Plugins 'hide' behind the WaveShell.
I need to send lists of installed plugins to contractors working for us.
@Avid, what's the solution for this?
Old 11-24-2022, 03:48 AM
Why wouldn't you try this? Courtesy of Darryl Ramm
Old 11-24-2022, 03:56 AM
Ben Jenssen's Avatar
Originally Posted by kosmokrator View Post
Hi there,
I use this:
PlugInfo: Audio Plugin Explorer
Very useful tool for checking installed plugins, versions etc. And you can select any and all plugins, right-click and select 'copy details', and paste into a word processor.
Unfortunately, Mac only, and it doesn't deal with the waveshell issue.
Price: $2.99.
Old 11-24-2022, 03:59 AM
Peter Gates PTPrefs. Scan plugins, select all, copy/paste into Numbers. Done.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
HTML code is On
Pro Tools Export / Region List Issue drewsmith Pro Tools 10 0 03-09-2012 05:13 AM
Plugin list? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-20-2010 08:03 AM
Print or Export Midi Event list tsoura 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-15-2008 08:35 AM
TL Space Plugin - Not in plugin list? joe.cavers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-31-2008 02:35 PM
LE with DVToolkit-no Export List!!??! MX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-25-2005 01:35 PM
