where is the SPDIF input in the mix window?
they are in my 24bit sessions but not in the 16bit ones.Instead there is some numbers(I/O ?)I can't get audio input for my DAT. -PTle 5.01 OS 9.4- thanx for infos. AdrianB. [img]images/icons/cool.gif[/img] |
Assuming you are trying to access the RCA S/PDIF I/O:
-Open the Setups>Playback Engine>Other Options within Pro Tools and set the Optical format to “ADAT.” -Open the Setups>Hardware>Sync Mode option within Pro Tools is set to “RCA S/PDIF.” -Open the Setups>I/O Setups window and click “Default” for the Inputs, Outputs and Inserts views. Brent |
Hi Brent,I have already access to SPDIF inputs with 24bit sessions, and all the setups are well done.What I can't find is the correct I/O box in the miw window, when I create a 16bit session(I have numbers instead of analog/SPDIF).Best regards.
AdrianB. |
How to get SPDIF inputs working? | roubignolle | Pro Tools M-Powered (Mac) | 0 | 01-05-2010 09:59 AM |
Multiple SPDIF inputs...? | GordonFreeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-17-2009 09:43 AM |
Pre-Amp / AD for my SPDIF inputs on Digi003 | AndyJCP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-08-2009 01:32 AM |
spdif inputs? | henryglover | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-07-2007 07:10 PM |
Can you add more spdif inputs and outputs to 002? | Sherbert99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-12-2006 02:51 PM |
