Old 10-13-2009, 01:50 PM
fooloof fooloof is offline
Default Pro Tools 8.0.1 not Detecting Microphone Inputs
I cannot get any levels from my mic pres into PT. I have:
1. PT8.0.1
2. Digi 003 Factory Console (6 mos old)
3. iMac 24" intel w/fast processor and 4G ram (OS 10.5.7 combo update)
Shure KSM 27 mic (requires phantom power)
AKG 1000s mic (requires phantom power)
Shure 58 (does not require phantom power)
I have tried all three mics to no avail. I have triple checked all connections and verified that phantom power has been activated. I also tried using different mic inputs in the back of the 003. The mics all work. After discovering this problem, I checked the mics in my Mackie board. I am only using one mic cable to troubleshoot everything. I do have a Digimax FS A/D converter hooked up, but that shouldn't affect anything. I have the PT tracks set for ANALOG recording, not ADAT.
This is the first time I've tried to record into PT8.
When I had M-Powered and the Project Mix, I was able to record no problem.
Thanks in advance for any help!
Old 10-13-2009, 02:02 PM
flommer flommer is offline
Default Re: Pro Tools 8.0.1 not Detecting Microphone Inputs
Go into I/O setup and reset all your inputs and outputs to default..,
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 10-13-2009, 02:23 PM
This may seem retarded, but: How do I reset to default? When I press the "default" button and then "ok", nothing seems to happen. For starters, I'm pretty sure my setting are at default, anyway. But, still, when I make changes to the i/o setup and then click "default" (and then "ok"), nothing happens. When I click out of the setup menu and then go back to i/o settings, they are still the same as before (meaning, reflecting any changes I made for testing purposes). Either way, it still doesn't work.
Thanks.
Old 10-13-2009, 02:54 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Ur pressing the Mic/line button so that its on Mic input correct?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 10-13-2009, 03:18 PM
Yes. I should have mentioned in the OP.
Old 10-13-2009, 03:39 PM
Do your line inputs work?
Does the digimax work?
Old 10-13-2009, 03:59 PM
Yes. The line inputs and Digimax work fine. I've recorded lots of stuff with this setup, but it's all been from instruments. Today is the first time I've tried to record from a microphone (and, now Madonna is getting impatient). Do you think trashing my prefs would help?
Old 10-13-2009, 04:22 PM
I should have answered "no." The Mic/Line button was pressed and lit up. I was wondering why mic and line were together, as I always understood that you couldn't have both options at the same time. I just found out from Tech Supt (on the phone) that the lit position means "line" and the unlit position means "mic." That was my problem. Now where did Madonna wonder off to...
Old 10-13-2009, 04:23 PM
Double check what KB said first... I believe the light should be off on the button to be in mic position...
If no go Then try the prefs...
Old 10-13-2009, 04:24 PM
This info is in the "003 getting started guide" too... Probably worth a gander...
Pro Tools SE Microphone set up UnionPacific7004 Pro Tools SE and Essential (Mac) 2 07-21-2013 12:02 PM
How to set up microphone with MBOX MINI 3 and PRO TOOLS 10 Ryuu macOS 2 02-09-2012 09:41 PM
HELP: Pro Tools LE 8 & sE Z3300a Microphone glenn1019 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-04-2012 02:02 PM
My M Box cant detecting the microphone Kstyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-14-2003 08:20 AM
Newbie-Detecting tempos in Pro Tools Free icequinn Digidesign Hardware & Software 0 11-07-2001 12:19 AM
